Aller au contenu principal
Toshiba Satellite M35X-S114 Hard Drive Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite M35X-S114 Hard Drive Replacement, Unlock the Battery from its Compartment: étape 1, image 1 de 2 Toshiba Satellite M35X-S114 Hard Drive Replacement, Unlock the Battery from its Compartment: étape 1, image 2 de 2
    • Locate the battery near the bottom left-hand side of the device.
    • Locate the two switches above the battery's top left corner.
    • Use any finger to move the smaller switch above the battery to the unlock position.
    • A small icon of a padlock will identify the "lock" and "unlock" positions of the switch.
  2. Toshiba Satellite M35X-S114 Hard Drive Replacement, Move the Battery's Release Switch: étape 2, image 1 de 2 Toshiba Satellite M35X-S114 Hard Drive Replacement, Move the Battery's Release Switch: étape 2, image 2 de 2
    • Use any finger to move the larger switch above the battery to the left and hold the switch.
  3. Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Battery: étape 3, image 1 de 2 Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Battery: étape 3, image 2 de 2
    • Place your fingernail or fingertip into the groove near the top right of the battery.
    • Pull the battery out with your finger. Release the larger switch once the battery is out.
  4. Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Hard Drive screw: étape 4, image 1 de 3 Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Hard Drive screw: étape 4, image 2 de 3 Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Hard Drive screw: étape 4, image 3 de 3
    • Locate the Hard Drive.
    • Locate the screw near the Hard Drive.
    • Use a Phillips 00 screwdriver to remove the 7.50mm screw.
  5. Toshiba Satellite M35X-S114 Hard Drive Replacement, Slide the Hard Drive out: étape 5, image 1 de 2 Toshiba Satellite M35X-S114 Hard Drive Replacement, Slide the Hard Drive out: étape 5, image 2 de 2
    • Please note that the hard drive from the laptop used is missing.
    • Slide the hard drive out.
    • The hard drive may not slide out easily, and may require a little bit of force in order to be disconnected from the laptop.
Christian Mayorga
Membre depuis le 09/09/14
219 Réputation
2 tutoriels rédigés
Équipe
CSU Fullerton, Team 2-4, Bruce Fall 2014 Membre de l'équipe CSU Fullerton, Team 2-4, Bruce Fall 2014
CSUF-BRUCE-F14S2G4
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 30
Total : 1,737
