Introduction
This guide describes how to remove the cooling unit of the Toshiba Satellite M45 laptop.
Pièces
Aucune pièce nécessaire.
Remove the cover from the cooling unit. Remove the cover from the cooling unit. Remove the cover from the cooling unit.
  • Remove the cover from the cooling unit.
Ajouter un commentaire
Unscrew the copper heat-sink using a #1 screwdriver, and then lift it free. Do not get any thermal grease on any components. This part can now be replaced. Unscrew the copper heat-sink using a #1 screwdriver, and then lift it free. Do not get any thermal grease on any components. This part can now be replaced.
  • Unscrew the copper heat-sink using a #1 screwdriver, and then lift it free. Do not get any thermal grease on any components. This part can now be replaced.
Follow the tear-down guide until you have access to the fan unit on the motherboard.
  • Follow the tear-down guide until you have access to the fan unit on the motherboard.
Unscrew the fan unit from the motherboard using a #0 screwdriver. Once the fan is unscrewed and unplugged from the motherboard, it can be replaced. Unscrew the fan unit from the motherboard using a #0 screwdriver. Once the fan is unscrewed and unplugged from the motherboard, it can be replaced. Unscrew the fan unit from the motherboard using a #0 screwdriver. Once the fan is unscrewed and unplugged from the motherboard, it can be replaced.
  • Unscrew the fan unit from the motherboard using a #0 screwdriver. Once the fan is unscrewed and unplugged from the motherboard, it can be replaced.
Stephen
Membre depuis le 20/04/2010
352 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 10-42, Garner Spring 2010 Membre de l'équipe Cal Poly, Team 10-42, Garner Spring 2010
CPSU-GARNER-S10S10G42
5 membres
10 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 5,310
