Introduction
This is a very difficult guide by the average user and is recommended to use headphones or external speakers.
Ce dont vous avez besoin
Flip the laptop to the bottom side.
Locate and slide the two battery locks to disconnect the battery.
Remove the battery by sliding it out away from the computer (horizontal with the casing).
Use a #1 Phillips head screwdriver to remove the screw on the middle right of the RAM's cover panel.
Then, use a the blue iFixit Opening Tool to pry the cover panel off.
Push on to the RAM tabs to disconnect the RAM form the device.
The RAM will pop off from the socket. Gently pull the RAM out of the socket.
Use the #1 Phillips head screwdriver to unscrew the panel.
Disconnect the black and white wires.
Push on the tabs to disconnect the Wi-Fi card.
Use the blue iFixit Opening Tool to pull the Wi-Fi Card out.
Use the #1 Phillips head screwdriver as to remove the hard drive screw.
Use the blue iFixit Opening Tool to pry the cover off.
Use the plastic flap to pull the hard drive out of its slot.
Use the #1 Phillips head screwdriver remove the Optical Drive screw.
Use the blue iFixit Opening Tool to pry the Optical Drive out of the slot from the side of the casing.
Use your hands to pull the rest of the Optical Drive out.
Carefully use the blue iFixit Opening Tool to pry the panel above the keyboard from the left and right side.
Push back the screen until it is flat with the laptop.
Gently remove the clips that connect the panel to the screen.
Disconnect the video cable, then slowly and firmly pull the video cable upwards.
Disconnect the brown ribbon located in the middle area of the laptop.
Disconnect the two white ribbons located in the bottom left of the laptop.
Firmly pull out the two white ribbons.
Located near the upper edges of the motherboard you will find the 2-speaker wires that trace to the speakers. You will see these white tab with black and red wires.
Unscrew the 2-screws located above the speakers to remove them. Slowly pull up on the speakers as there are other port connectors are located near the wiring.
