Introduction
This guide illustrates how to replace the RAM in your Toshiba Satellite.
Pièces
Orient the laptop so that it is closed, faced down and has the battery facing away from you.
  • Orient the laptop so that it is closed, faced down and has the battery facing away from you.
  • Use the Phillips 00 screwdriver to remove the 7.50mm screw from the panel.
Ajouter un commentaire
Carefully remove the cover to reveal the RAM compartment.
  • Carefully remove the cover to reveal the RAM compartment.
Rotate the laptop 90 degrees clockwise. Pull back the two silver clips that hold the RAM in place.
  • Rotate the laptop 90 degrees clockwise.
  • Pull back the two silver clips that hold the RAM in place.
  • Gently pull the RAM out of the slot and lift up to remove the RAM from the laptop.
Matthew Trinh
Membre depuis le 31/01/2013
63 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 7-11, Maness Winter 2013 Membre de l'équipe Cal Poly, Team 7-11, Maness Winter 2013
CPSU-MANESS-W13S7G11
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 4
Total : 1,033
