Aller au contenu principal
Toshiba Satellite P205-S8811 RAM Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite P205-S8811 RAM Replacement, Battery: étape 1, image 1 de 2 Toshiba Satellite P205-S8811 RAM Replacement, Battery: étape 1, image 2 de 2
    • Flip the laptop over so the bottom is facing upward and the battery is on top.
    • Slide the tab below the battery to the left.
  2. Toshiba Satellite P205-S8811 RAM Replacement: étape 2, image 1 de 2 Toshiba Satellite P205-S8811 RAM Replacement: étape 2, image 2 de 2
    • Slide and hold the tab on the right side of the battery to the right.
    • While holding the right tab, slide the battery upward and out its socket.
  3. Toshiba Satellite P205-S8811 RAM Replacement, RAM: étape 3, image 1 de 1
    • Locate the RAM slot cover on the bottom of the laptop. The RAM slot cover is located near the battery slot.
  4. Toshiba Satellite P205-S8811 RAM Replacement: étape 4, image 1 de 1
    • Using a Phillips-head screwdriver, unscrew and remove the screw holding the RAM slot cover in place.
  5. Toshiba Satellite P205-S8811 RAM Replacement: étape 5, image 1 de 2 Toshiba Satellite P205-S8811 RAM Replacement: étape 5, image 2 de 2
    • Lift and remove the RAM slot cover.
  6. Toshiba Satellite P205-S8811 RAM Replacement: étape 6, image 1 de 2 Toshiba Satellite P205-S8811 RAM Replacement: étape 6, image 2 de 2
    • To remove the first RAM chip, gently press outward on the tabs on both sides of the chip
    • The RAM chip should pop up after releasing the tabs.
  7. Toshiba Satellite P205-S8811 RAM Replacement: étape 7, image 1 de 1
    • Using your fingers, remove the RAM chip by gently pulling it out of the RAM slot.
  8. Toshiba Satellite P205-S8811 RAM Replacement: étape 8, image 1 de 2 Toshiba Satellite P205-S8811 RAM Replacement: étape 8, image 2 de 2
    • To remove the second RAM chip, repeat the previous steps
Davin
Membre depuis le 02/03/14
271 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 2-8, Amido Winter 2014 Membre de l'équipe Cal Poly, Team 2-8, Amido Winter 2014
CPSU-AMIDO-W14S2G8
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 14
Total : 467
