Introduction
This guide will show you how to replace the RAM on your laptop. There are two RAM slots in this laptop that can be swapped out for other RAM chips.
Pièces
Aucune pièce nécessaire.
To prevent injury, ensure the laptop is powered off before starting your work. Unscrew the .3mm Phillips head screws on the back panel using the PH1 screwdriver.
  • To prevent injury, ensure the laptop is powered off before starting your work.
  • Unscrew the .3mm Phillips head screws on the back panel using the PH1 screwdriver.
Ajouter un commentaire
Be careful to not crack the panel where the USB and power cord ports are. Insert the opening tool in between the back panel and the laptop to pry it open. The back panel is magnetically attached at the front of the laptop so you may have to move the opening tool along the length of the panel.
  • Be careful to not crack the panel where the USB and power cord ports are.
  • Insert the opening tool in between the back panel and the laptop to pry it open.
  • The back panel is magnetically attached at the front of the laptop so you may have to move the opening tool along the length of the panel.
  • Lift the panel from the front off of the laptop.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
The battery is located in the bottom right corner of the laptop. Remove the four .5mm Phillips head screws on the battery using the PH1 screwdriver. Remove the four .5mm Phillips head screws on the battery using the PH1 screwdriver.
  • The battery is located in the bottom right corner of the laptop.
  • Remove the four .5mm Phillips head screws on the battery using the PH1 screwdriver.
Do not tug on the cord or battery. Instead, pull evenly on the connector. Lift the battery and gently pull out the bundled cable connector.
  • Do not tug on the cord or battery. Instead, pull evenly on the connector.
  • Lift the battery and gently pull out the bundled cable connector.
Lift up the flap to expose the RAM chip. Un-clip the RAM by pulling the metal clips away from the chip on both sides. Lift the RAM up from the laptop and pull it away from the connector.
  • Lift up the flap to expose the RAM chip.
  • Un-clip the RAM by pulling the metal clips away from the chip on both sides.
  • Lift the RAM up from the laptop and pull it away from the connector.
Alec Bonnell
Membre depuis le 18/10/2017
434 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G2, Bailey Fall 2017 Membre de l'équipe UMass Dartmouth, Team S3-G2, Bailey Fall 2017
UMASSD-BAILEY-F17S3G2
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 8
Total : 51
