Introduction
In this guide you will be replacing the Wi-Fi adapter in your laptop. You'll need to use a Phillips #1 screwdriver to complete this repair.
Pièces
Aucune pièce nécessaire.
Slide the tabs apart from each other.
  • Slide the tabs apart from each other.
Ajouter un commentaire
Lift the battery upwards and remove it from the device. Lift the battery upwards and remove it from the device.
  • Lift the battery upwards and remove it from the device.
Kits de RAM Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits de RAM Mac
Obtenez plus de mémoire sur votre Mac.
Using a Phillips #1 screwdriver, remove the screw from the back cover. Remove the back cover from the device.
  • Using a Phillips #1 screwdriver, remove the screw from the back cover.
  • Remove the back cover from the device.
Remove the optical drive from the device. Remove the optical drive from the device. Remove the optical drive from the device.
  • Remove the optical drive from the device.
Using a Phillips #1 screwdriver, unscrew the remaining screws that are visible on the laptop. Remove the back cover from your device.
  • Using a Phillips #1 screwdriver, unscrew the remaining screws that are visible on the laptop.
  • Remove the back cover from your device.
Using a Phillips #1 screwdriver, remove the screw connecting the Wi-Fi adapter to the motherboard. Remove the Wi-Fi adapter from the device. Remove the Wi-Fi adapter from the device.
  • Using a Phillips #1 screwdriver, remove the screw connecting the Wi-Fi adapter to the motherboard.
  • Remove the Wi-Fi adapter from the device.
Brandon Cole
Membre depuis le 17/01/2018
259 Réputation
1 tutoriel rédigé
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 21
