Introduction
If you find that your laptop is sluggish when many programs are running, freezing, or randomly restarting. It may be time to add more RAM or replace the RAM currently in the laptop.
Pièces
Unscrew the panel using the PH0
  • Unscrew the panel using the PH0
    • The screw is attached to the panel, and will not be able to be removed.
Ajouter un commentaire
Lift up panel cover. You should be able to do this using your finger with little effort.
  • Lift up panel cover. You should be able to do this using your finger with little effort.
Using a plastic tool, push the latches away from the RAM. The RAM will then lift up on its own and the latches will spring back into place.
  • Using a plastic tool, push the latches away from the RAM.
  • The RAM will then lift up on its own and the latches will spring back into place.
    • This will only release the RAM stick that is on top. Repeat these steps again to release another RAM stick.
Pull out the released RAM stick which is now lifted up at an angle. It should not require any effort to remove. Use same steps for other RAM sticks that are released.
  • Pull out the released RAM stick which is now lifted up at an angle. It should not require any effort to remove.
  • Use same steps for other RAM sticks that are released.
When installing the new RAM, push the RAM sticks in at an angle. Proceed to push each RAM stick down until the latches click, indicating that it is locked in.
William Mazanec
Membre depuis le 29/01/2018
1 142 Réputation
8 tutoriels rédigés
Équipe
USF Tampa, Team S5-G6, Passmore Spring 2018 Membre de l'équipe USF Tampa, Team S5-G6, Passmore Spring 2018
USFT-PASSMORE-S18S5G6
3 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 49
