Introduction
If you find that your laptop no longer connects to a Wi-Fi connection, or the computer runs very well but connecting to the internet is sluggish. It may be time to replace the wireless network card.
Remove the 14, 5mm screws using the PH0, and place them onto the project mat.
  • Remove the 14, 5mm screws using the PH0, and place them onto the project mat.
Ajouter un commentaire
Using the plastic prying tools, go around the edge of the back of the laptop to release the back cover.
  • Using the plastic prying tools, go around the edge of the back of the laptop to release the back cover.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Unplug the black and white cables that connect the wireless network card to the laptop.
  • Unplug the black and white cables that connect the wireless network card to the laptop.
  • After replacing the Wireless Network Card, you will need to apply pressure and wait for a snapping sound indicating that the cables are reconnected.
Using the PH0, remove the 3mm screw holding the wireless network card to the laptop.
  • Using the PH0, remove the 3mm screw holding the wireless network card to the laptop.
    • Place the screw on your project mat.
    • The card will lift up once the screw is out.
William Mazanec
Membre depuis le 29/01/2018
1 142 Réputation
8 tutoriels rédigés
Équipe
USF Tampa, Team S5-G6, Passmore Spring 2018 Membre de l'équipe USF Tampa, Team S5-G6, Passmore Spring 2018
USFT-PASSMORE-S18S5G6
3 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 55
