Introduction
The faceplate is the area next to the keyboard that protects the inside parts of the device. Sometimes it may need to be taken off to repair other parts. This guide will show how to remove it.
Make sure that the laptop is off and unplugged.
  • Make sure that the laptop is off and unplugged.
  • Turn the laptop over.
  • Slide back the left lock, and you should hear a click when it is successfully locked back in.
Ajouter un commentaire
Rotate the laptop 180 degrees so that the battery is near you.
  • Rotate the laptop 180 degrees so that the battery is near you.
  • Hold back the spring slide and pull the battery out.
Situate the laptop so that it is open and the display is facing you. Use the plastic opening tool to pry the black plastic insert upward. The insert can be found at the top of the keyboard. Once the insert is loose, carefully remove it from the device.
  • Situate the laptop so that it is open and the display is facing you.
  • Use the plastic opening tool to pry the black plastic insert upward. The insert can be found at the top of the keyboard.
    • Once the insert is loose, carefully remove it from the device.
Using #1 Phillips Screwdriver, remove both of the 5 mm screws that are located beneath the insert. Using #1 Phillips Screwdriver, remove both of the 5 mm screws that are located beneath the insert.
  • Using #1 Phillips Screwdriver, remove both of the 5 mm screws that are located beneath the insert.
Use the plastic opening tool to begin removing the keys off of the device. Once the keys are off, gently remove the keyboard. Be careful of the ribbon cable that still connects the keyboard to motherboard.
  • Use the plastic opening tool to begin removing the keys off of the device.
    • Once the keys are off, gently remove the keyboard. Be careful of the ribbon cable that still connects the keyboard to motherboard.
Lift up the gate on the ZIF socket to release the ribbon. Ease the ribbon connecting the keyboard to the motherboard out of the ZIF socket.
  • Lift up the gate on the ZIF socket to release the ribbon.
  • Ease the ribbon connecting the keyboard to the motherboard out of the ZIF socket.
With the keyboard removed, locate the marked screws. Remove the marked, 5mm screws using the #1 Phillips Screwdriver.
  • With the keyboard removed, locate the marked screws.
  • Remove the marked, 5mm screws using the #1 Phillips Screwdriver.
In the opening above the mouse pad, use the plastic opening tool to push up the black gate of the ZIF socket. Remove the ribbon from the ZIF socket.
  • In the opening above the mouse pad, use the plastic opening tool to push up the black gate of the ZIF socket.
  • Remove the ribbon from the ZIF socket.
Locate the wide opening at the top near the screen. Use the plastic opening tool to open the black ZIF socket. Remove the blue ribbon.
  • Locate the wide opening at the top near the screen.
  • Use the plastic opening tool to open the black ZIF socket.
  • Remove the blue ribbon.
After removing the screw in step 3, carefully close the laptop and put it face down. Locate the center panel. Remove the three, 3 mm screws using the #1 Phillips Screwdriver.
  • After removing the screw in step 3, carefully close the laptop and put it face down. Locate the center panel.
  • Remove the three, 3 mm screws using the #1 Phillips Screwdriver.
Grasp the power cable with your tweezers and remove it from the wireless antenna. Grasp the power cable with your tweezers and remove it from the wireless antenna.
  • Grasp the power cable with your tweezers and remove it from the wireless antenna.
Locate and remove both the white and black antenna leads with the tweezers. Locate and remove both the white and black antenna leads with the tweezers.
  • Locate and remove both the white and black antenna leads with the tweezers.
Remove screws for back assembly. 11 x F5 (5 mm #1 Phillips) 6 x F2 (2 mm #0 Phillips)
  • Remove screws for back assembly.
  • 11 x F5 (5 mm #1 Phillips)
  • 6 x F2 (2 mm #0 Phillips)
  • 4 x F8 (8 mm #1 Phillips)
  • 1 x F3 (3 mm #1 Phillips
Use the plastic opening tool to release the back panel from the laptop.
  • Use the plastic opening tool to release the back panel from the laptop.
  • If all of the screws are removed it should come off with very little effort. Do not force it. If it still feels attached, check that you didn't miss a screw or two.
Use the plastic opening tool to separate the top faceplate. The faceplate is the plastic surface and the metal piece under the keyboard.
  • Use the plastic opening tool to separate the top faceplate.
    • The faceplate is the plastic surface and the metal piece under the keyboard.
  • Carefully lift the faceplate off of the base by sliding the plastic opening tool around the outside of the device. You'll hear clicks as you do this.
    • Prying apart the faceplate will be a little hard, but try not to bend it too much - you do not want to crack it.
Lift the back panel and carefully disconnect the main power cable.
  • Lift the back panel and carefully disconnect the main power cable.
Remove the black signal cable attached at the blue circuit board. Remove the black signal cable attached at the blue circuit board.
  • Remove the black signal cable attached at the blue circuit board.
Remove auxiliary power cable attached to the blue board at the back of the laptop. Remove auxiliary power cable attached to the blue board at the back of the laptop.
  • Remove auxiliary power cable attached to the blue board at the back of the laptop.
Brandon Kirklen
Membre depuis le 11/01/2013
269 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 7-8, Maness Winter 2013 Membre de l'équipe Cal Poly, Team 7-8, Maness Winter 2013
CPSU-MANESS-W13S7G8
4 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 731
