Aller au contenu principal
Toshiba Satellite U405D-S2902 Keyboard Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite U405D-S2902 Keyboard Replacement, Keyboard: étape 1, image 1 de 3 Toshiba Satellite U405D-S2902 Keyboard Replacement, Keyboard: étape 1, image 2 de 3 Toshiba Satellite U405D-S2902 Keyboard Replacement, Keyboard: étape 1, image 3 de 3
    • Situate the laptop so that it is open and the display is facing you.
    • Use the plastic opening tool to pry the black plastic insert upward. The insert can be found at the top of the keyboard.
    • Once the insert is loose, carefully remove it from the device.
  2. Toshiba Satellite U405D-S2902 Keyboard Replacement: étape 2, image 1 de 2 Toshiba Satellite U405D-S2902 Keyboard Replacement: étape 2, image 2 de 2
    • Using #1 Phillips Screwdriver, remove both of the 5 mm screws that are located beneath the insert.
  3. Toshiba Satellite U405D-S2902 Keyboard Replacement: étape 3, image 1 de 2 Toshiba Satellite U405D-S2902 Keyboard Replacement: étape 3, image 2 de 2
    • Use the plastic opening tool to begin removing the keys off of the device.
    • Once the keys are off, gently remove the keyboard. Be careful of the ribbon cable that still connects the keyboard to motherboard.
  4. Toshiba Satellite U405D-S2902 Keyboard Replacement: étape 4, image 1 de 2 Toshiba Satellite U405D-S2902 Keyboard Replacement: étape 4, image 2 de 2
    • Lift up the gate on the ZIF socket to release the ribbon.
    • Ease the ribbon connecting the keyboard to the motherboard out of the ZIF socket.
2 autres ont terminé cette réparation.
Brandon Kirklen
Membre depuis le 01/11/13
311 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 7-8, Maness Winter 2013 Membre de l'équipe Cal Poly, Team 7-8, Maness Winter 2013
CPSU-MANESS-W13S7G8
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 1
Total : 601
