Aller au contenu principal
Toshiba Satellite U405D-S2902 RAM Replacement
Ce dont vous avez besoin
  1. Toshiba Satellite U405D-S2902 RAM Replacement, RAM: étape 1, image 1 de 2 Toshiba Satellite U405D-S2902 RAM Replacement, RAM: étape 1, image 2 de 2
    • Lay the device face down with the battery facing away from you. Locate the center panel. It will have two vents in it and three screws on the left side.
    • Loosen the three screws that hold the rear access panel on, using your Phillips #1 Screwdriver.
    • The screws will not actually come out from the panel but will be loose and let the panel come off.
    • Lift the left side of the panel to remove it.
  2. Toshiba Satellite U405D-S2902 RAM Replacement: étape 2, image 1 de 1
    • Locate and pull back the two mounting clips on either side of the memory chip.
    • Be sure that when replacing the board, push down gently until the clips snap back in.
  3. Toshiba Satellite U405D-S2902 RAM Replacement: étape 3, image 1 de 2 Toshiba Satellite U405D-S2902 RAM Replacement: étape 3, image 2 de 2
    • Lift RAM circuit board to about a 45 degree angle and pull gently to the right.
That's it for hardware, the remaining steps will depend on the software platform being run on your laptop.
2 autres ont terminé cette réparation.
Brandon Kirklen
Membre depuis le 01/11/13
311 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 7-8, Maness Winter 2013 Membre de l'équipe Cal Poly, Team 7-8, Maness Winter 2013
CPSU-MANESS-W13S7G8
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 8
Total : 610
