Introduction
Tablet screens often get damaged, this guide will walk a user through the steps of replacing a damaged screen. It is important to be careful about damaging parts, as most pieces are fragile.
Pièces
Aucune pièce nécessaire.
Locate the indentation at the bottom of the device. Locate the indentation at the bottom of the device.
  • Locate the indentation at the bottom of the device.
Ajouter un commentaire
Pull on the indentation and take off the casing of the device. Pull on the indentation and take off the casing of the device. Pull on the indentation and take off the casing of the device.
  • Pull on the indentation and take off the casing of the device.
Remove the faulty battery and insert a replacement in its slot. Remove the faulty battery and insert a replacement in its slot.
  • Remove the faulty battery and insert a replacement in its slot.
Remove the six 2.4 mm, Phillips #0 screws circled in the image.
  • Remove the six 2.4 mm, Phillips #0 screws circled in the image.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove inner casing exposing the motherboard.
  • Remove inner casing exposing the motherboard.
Remove speakers by peeling back yelllow tape. Remove speakers by peeling back yelllow tape.
  • Remove speakers by peeling back yelllow tape.
Remove ribbon cable on top of motherboard.
  • Remove ribbon cable on top of motherboard.
Peeling back yellow tape, remove the 2.5 mm Phillips #0 screws on top of motherboard.
  • Peeling back yellow tape, remove the 2.5 mm Phillips #0 screws on top of motherboard.
Remove the three 2.5 mm Phillips #0 screws attaching screen to main assembly.
  • Remove the three 2.5 mm Phillips #0 screws attaching screen to main assembly.
Verify that all screws are detached from screen.
  • Verify that all screws are detached from screen.
Detach screen from main assembly.
  • Detach screen from main assembly.
Stewart Jenkins
Membre depuis le 26/03/2018
207 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S1-G1, Harley Spring 2018 Membre de l'équipe IUPUI, Team S1-G1, Harley Spring 2018
IUPUI-HARLEY-S18S1G1
7 membres
2 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 10
Total : 35
