Introduction
This guide will show you how to replace the LED lights for the Tt Esports Poseidon keyboard.
Pièces
Aucune pièce nécessaire.
Flip the keyboard over.
  • Flip the keyboard over.
Ajouter un commentaire
Remove the three JIS #1 screws from the back cover. Remove the three JIS #1 screws from the back cover.
  • Remove the three JIS #1 screws from the back cover.
Pry at these points with a plastic opening tool to unclip the two halves of the keyboard case. Pry at these points with a plastic opening tool to unclip the two halves of the keyboard case.
  • Pry at these points with a plastic opening tool to unclip the two halves of the keyboard case.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Pull apart the two parts of the panel to expose the motherboard and keys.
  • Pull apart the two parts of the panel to expose the motherboard and keys.
Use a plastic opening tool to pry off every key. Use a plastic opening tool to pry off every key.
  • Use a plastic opening tool to pry off every key.
The space, +, enter, shift, insert, and backspace keys all have metal parts which might make it a little harder to remove. Pull these keys to the side and up. Pull these keys to the side and up.
  • The space, +, enter, shift, insert, and backspace keys all have metal parts which might make it a little harder to remove.
  • Pull these keys to the side and up.
Since the LED lights are connected to every key, you will need to replace this whole part.
  • Since the LED lights are connected to every key, you will need to replace this whole part.
2 autre(s) ont terminé cette réparation.
Hailey Cheatham
Membre depuis le 21/02/2018
97 Réputation
1 tutoriel rédigé
Équipe
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 9
Total : 29
