Introduction
The motherboard is the central processing unit for the keyboard. This guide will help you replace the motherboard in your keyboard. You will need plastic opening tools, and a screw driver with a J1 bit.
Pièces
Aucune pièce nécessaire.
Flip the keyboard over.
  • Flip the keyboard over.
Ajouter un commentaire
Remove the three JIS #1 screws from the back cover. Remove the three JIS #1 screws from the back cover.
  • Remove the three JIS #1 screws from the back cover.
Pry at these points with a plastic opening tool to unclip the two halves of the keyboard case. Pry at these points with a plastic opening tool to unclip the two halves of the keyboard case.
  • Pry at these points with a plastic opening tool to unclip the two halves of the keyboard case.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Pull apart the two parts of the panel to expose the motherboard and keys.
  • Pull apart the two parts of the panel to expose the motherboard and keys.
Use a plastic opening tool to pry off every key. Use a plastic opening tool to pry off every key.
  • Use a plastic opening tool to pry off every key.
The space, +, enter, shift, insert, and backspace keys all have metal parts which might make it a little harder to remove. Pull these keys to the side and up. Pull these keys to the side and up.
  • The space, +, enter, shift, insert, and backspace keys all have metal parts which might make it a little harder to remove.
  • Pull these keys to the side and up.
Now that the motherboard has been removed from the keyboard,  you can put a new motherboard in place of your broken one.
  • Now that the motherboard has been removed from the keyboard, you can put a new motherboard in place of your broken one.
Marta Darmanyan
Membre depuis le 21/02/2018
401 Réputation
3 tutoriels rédigés
Équipe
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 18
