Introduction
This is a repair guide for battery replacement.
To reach the battery, follow steps 1 through 3 in the Tungsten E Teardown
Ajouter un commentaire
Begin to pry up the battery.  It is fastened to the mother board using two sided tape.
  • Begin to pry up the battery. It is fastened to the mother board using two sided tape.
  • Caution: the battery is connected by two wires.
Remove the battery
  • Remove the battery
  • Caution: Be careful not to tear the wires when removing battery.
Using a soldering iron, disconnect the battery wires.
  • Using a soldering iron, disconnect the battery wires.
  • Note: the wires are soldered to the board.
Take replacement battery and solder the wires to the board.
  • Take replacement battery and solder the wires to the board.
  • Take care to match wire colors as before.
  • Use double sided tape to attach battery firmly to board.
Kathleen Hix
Membre depuis le 21/01/2010
49 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 13-22, Maness Winter 2010 Membre de l'équipe Cal Poly, Team 13-22, Maness Winter 2010
CPSU-MANESS-W10S13G22
4 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 12
Total : 5,633
