Aller au contenu principal
UP! Plus 2 Spool Holder Replacement
Ce dont vous avez besoin
  1. UP! Plus 2 Spool Holder Replacement, 3D print replacement spool holder: étape 1, image 1 de 1
    • Before your spool holder breaks, 3D print a replacement to have on hand. If you didn't preemptively print a replacement you can still print without a spool holder. Just find some way of holding the spool so that it can rotate as the filament gets pulled off.
    • Download the file for a new spool holder here
  2. UP! Plus 2 Spool Holder Replacement, Remove plastic filaments: étape 2, image 1 de 3 UP! Plus 2 Spool Holder Replacement, Remove plastic filaments: étape 2, image 2 de 3 UP! Plus 2 Spool Holder Replacement, Remove plastic filaments: étape 2, image 3 de 3
    • Go to "Maintenance" and tell the printer to withdraw the plastic filament from the extrusion assembly. Finish removing the filament by pulling upwards.
    • Wait for a "beeping" sound before removing filament.
    • Cut off any damaged plastic from the end of the filament.
    • Remove the plastic filament tube from the spool.
  3. UP! Plus 2 Spool Holder Replacement, Remove spool holder: étape 3, image 1 de 3 UP! Plus 2 Spool Holder Replacement, Remove spool holder: étape 3, image 2 de 3 UP! Plus 2 Spool Holder Replacement, Remove spool holder: étape 3, image 3 de 3
    • Remove the spool from the spool holder by lifting it up and taking it off.
    • Put the end of the filament through the hole on the side of the spool to keep it from unraveling.
    • Slide the spool holder upwards, and then pull outwards.
  4. UP! Plus 2 Spool Holder Replacement, Replace spool holder: étape 4, image 1 de 3 UP! Plus 2 Spool Holder Replacement, Replace spool holder: étape 4, image 2 de 3 UP! Plus 2 Spool Holder Replacement, Replace spool holder: étape 4, image 3 de 3
    • Place the new spool holder by pushing it inwards and sliding it down until it locks.
    • Repeat the steps in reverse chronological order to reassemble the printer.
    • The spool should be inserted in way that end of the filament points towards, not away.
Ligne d'arrivée
6 autres ont terminé cette réparation.
valerie boyer
Membre depuis le 10/12/14
508 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 14-31, Maness Fall 2014 Membre de l'équipe Cal Poly, Team 14-31, Maness Fall 2014
CPSU-MANESS-F14S14G31
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 8
Total : 1,206
