Introduction
This guide entails and explains the simple steps to replace the non-functioning keyboard on the Uniden Dect 6.0 home phone.
Locate the battery compartment on the back of the Uniden home phone.
  • Locate the battery compartment on the back of the Uniden home phone.
  • Place your finger on groove, and pull directly back on the cover to gain access to the battery.
the hand set does not work nither one will charge I just bought it from Walmart in sant cloud florida I have the uniden 6.0 answering mic plus the 2 hand sets 1 for the base and 1 for the ex phone what do I do because I had it on charge for 2 days now.i m disabled and need I phone to work thank you for any help u can give me or please send me 2 batterys 1 for each phone and I will send the 2 I just got with my new phone hope that works after I replace the batterys ty u can send to 1311 w rosewood ave sant cloud florida 34771 thank you
star - Réponse
Remove the white battery pack from the battery compartment.
  • Remove the white battery pack from the battery compartment.
Ajouter un commentaire
Remove the red and black  wired port from the plug in located directly under the battery compartment.
  • Remove the red and black wired port from the plug in located directly under the battery compartment.
Using a phillips #1 screw driver, remove the two .9 mm phillips screws on the back of the device located on both sides of the battery pack. Using a phillips #1 screw driver, remove the two .9 mm phillips screws on the back of the device located on both sides of the battery pack.
  • Using a phillips #1 screw driver, remove the two .9 mm phillips screws on the back of the device located on both sides of the battery pack.
Gently lift and separate the front of the housing from the back housing using your fingers.
  • Gently lift and separate the front of the housing from the back housing using your fingers.
  • While separating the back housing from the front, be sure to open from sides as pictured and not from the top or bottom of the phone. Doing so could damage inside cables or motherboard piece!
Gently remove the loose keyboard from the lined gel casing located under the front housing of the front of the phone.
  • Gently remove the loose keyboard from the lined gel casing located under the front housing of the front of the phone.
Megan Lawrence
Membre depuis le 14/01/2015
528 Réputation
5 tutoriels rédigés
Équipe
USF Sarasota-Manatee, Team 1-3, Stewart Winter 2015 Membre de l'équipe USF Sarasota-Manatee, Team 1-3, Stewart Winter 2015
USFSM-STEWART-W15S1G3
4 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 13
30 derniers jours : 52
Total : 1,448
