Pièces
Aucune pièce nécessaire.
Refer to the Uniden EXP 371 phone disassembly guide to open the plastic casing.
  • Refer to the Uniden EXP 371 phone disassembly guide to open the plastic casing.
Ajouter un commentaire
Use the Phillips #1 screwdriver to unscrew the screws located at the bottom left and right hand corners and top of the phone; as shown in the image. Use the Phillips #1 screwdriver to unscrew the screws located at the bottom left and right hand corners and top of the phone; as shown in the image. Use the Phillips #1 screwdriver to unscrew the screws located at the bottom left and right hand corners and top of the phone; as shown in the image.
  • Use the Phillips #1 screwdriver to unscrew the screws located at the bottom left and right hand corners and top of the phone; as shown in the image.
Remove the motherboard once the screws holding it in place are undone. Once the motherboard has been removed, remove the rubber button pad located behind the motherboard and in front of the dial pad.
  • Remove the motherboard once the screws holding it in place are undone.
  • Once the motherboard has been removed, remove the rubber button pad located behind the motherboard and in front of the dial pad.
After the rubber pad is removed remove the dial pad (buttons) from the phone.
  • After the rubber pad is removed remove the dial pad (buttons) from the phone.
If the buttons are sticky; leaving the dial pad and/or rubber pad to soak in soap and water for 5-10 minutes will clean off any sticky residue that may be obstructing the buttons. Make sure to properly dry the dial pad and rubber pad of any soap/water before reattaching them to the phone to avoid the risk of short circuiting.
  • If the buttons are sticky; leaving the dial pad and/or rubber pad to soak in soap and water for 5-10 minutes will clean off any sticky residue that may be obstructing the buttons.
  • Make sure to properly dry the dial pad and rubber pad of any soap/water before reattaching them to the phone to avoid the risk of short circuiting.
If sticky residue is not the problem the next step is to visit http://udn.factoryoutletstore.com and search for the UNIDEN EXP 371 and order a new dial pad.
Lucas Mohsen
Membre depuis le 31/10/2014
101 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 2-1, Duarte Fall 2014 Membre de l'équipe UMass Dartmouth, Team 2-1, Duarte Fall 2014
UMASSD-DUARTE-F14S2G1
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 79
