Place the phone facedown on a cleared work area Remove the back case by applying moderate force to the indentation in the lower left corner of the case.
  • Place the phone facedown on a cleared work area
  • Remove the back case by applying moderate force to the indentation in the lower left corner of the case.
Ajouter un commentaire
Grip the top right corner of the battery.
  • Grip the top right corner of the battery.
  • Remove the battery by pulling it outwards.
Remove the four screws on the back of the phone using a Philips 000 screwdriver
  • Remove the four screws on the back of the phone using a Philips 000 screwdriver
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Separate the frame evenly using a plastic opening tool.
  • Separate the frame evenly using a plastic opening tool.
  • Be careful, as the frame is thin and can break easily.
Use a Phillips #000 screwdriver to remove the four screws that secure the motherboard. Use a Phillips #000 screwdriver to remove the four screws that secure the motherboard.
  • Use a Phillips #000 screwdriver to remove the four screws that secure the motherboard.
Disconnect the ribbon cable from the motherboard using rounded, spade-tipped tweezers.
  • Disconnect the ribbon cable from the motherboard using rounded, spade-tipped tweezers.
Peel the white circuit on left side of the frame by inserting fine-tipped tweezers between it and the frame.
  • Peel the white circuit on left side of the frame by inserting fine-tipped tweezers between it and the frame.
  • The white circuit is flimsy and securely glued to the frame.
Set aside the circuit board from the screen protector. Set aside the circuit board from the screen protector.
  • Set aside the circuit board from the screen protector.
Peel back the speaker using fine-tipped tweezers Use caution when removing the earpiece speaker
  • Peel back the speaker using fine-tipped tweezers
  • Use caution when removing the earpiece speaker
Esteban Almeida
Membre depuis le 08/02/2018
329 Réputation
2 tutoriels rédigés
Équipe
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 9
Total : 34
