Introduction
Replace the antenna to address internet connection problems. This replacement is fast, simple, and requires no tools.
Orient the router to where the back side with the ports faces you.
  • Orient the router to where the back side with the ports faces you.
Ajouter un commentaire
Lower the antenna so that it is parallel to the table surface.
  • Lower the antenna so that it is parallel to the table surface.
Unscrew the antenna counterclockwise at the threaded base until it is detached. Unscrew the antenna counterclockwise at the threaded base until it is detached.
  • Unscrew the antenna counterclockwise at the threaded base until it is detached.
James Carby
Membre depuis le 17/09/2014
189 Réputation
1 tutoriel rédigé
Équipe
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 234
