Introduction
To replace the refresh button, you will need to open the router's outer casings. This replacement is simple and will not take much time to complete.
Pièces
Aucune pièce nécessaire.
Flip the device so that the bottom is facing up.
  • Flip the device so that the bottom is facing up.
Ajouter un commentaire
Insert the plastic-opening tool under the silver labeled casing. Carefully pry at different intervals around the silver labeled casing to separate the silver casing from the top and bottom casing. Carefully pry at different intervals around the silver labeled casing to separate the silver casing from the top and bottom casing.
  • Insert the plastic-opening tool under the silver labeled casing.
  • Carefully pry at different intervals around the silver labeled casing to separate the silver casing from the top and bottom casing.
Unscrew the five 10-mm screws on the bottom of the router using a Phillips #0 screwdriver. Unscrew the five 10-mm screws on the bottom of the router using a Phillips #0 screwdriver.
  • Unscrew the five 10-mm screws on the bottom of the router using a Phillips #0 screwdriver.
Use a plastic-opening tool and pry the top casing from the bottom casing to expose the circuit board in the bottom half of the device. Use a plastic-opening tool and pry the top casing from the bottom casing to expose the circuit board in the bottom half of the device.
  • Use a plastic-opening tool and pry the top casing from the bottom casing to expose the circuit board in the bottom half of the device.
Locate the refresh button.
  • Locate the refresh button.
Apply pressure with your finger to the black tab that retains the refresh button while using your other hand to pull the bottom of the refresh button from the post. Apply pressure with your finger to the black tab that retains the refresh button while using your other hand to pull the bottom of the refresh button from the post. Apply pressure with your finger to the black tab that retains the refresh button while using your other hand to pull the bottom of the refresh button from the post.
  • Apply pressure with your finger to the black tab that retains the refresh button while using your other hand to pull the bottom of the refresh button from the post.
Jeffrey Fox
Membre depuis le 17/09/2014
305 Réputation
3 tutoriels rédigés
Équipe
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 208
