Introduction
This repair guide will show the reader how to fix the Scroll Wheel on a VicTsing wireless mouse.
Ce dont vous avez besoin
Remove the battery cover, and batteries from the compartment. Then use the metal spudger to peel back the adhesives.
16 autres ont terminé cette réparation.
16 commentaires
Very detailed repair guide!!!
THANK YOU! Saved me from spending another $10 on a mouse after 6 months. Those screws under the adhesives are pretty hidden…
Thanks! I was thinking to buy another but it is fixed! It works on the model VicTsing CA32-es2 too, that’s mine.
Excellent guide, thanks! I have a Victsing PC134A vertical mouse. The assembly is different, so I ended up removing about 12 screws, only to then realize that I could easily access the “rotary encoder” part with zero screw removal. :) For Victsing PC134A, just pop off the the left-right click cover, and tweeze as suggested in this guide. It worked!
That’s crazy! Why does squeezing the rotary encoder fix it? Thank you so much for the guide!
