Introduction
In this guide, we will be showing you how to remove and replace the Memory Modules.
Pièces
Aucune pièce nécessaire.
Slide the battery lock latches into the unlocked position.
  • Slide the battery lock latches into the unlocked position.
Ajouter un commentaire
Slide the battery toward the back of the computer to remove.
  • Slide the battery toward the back of the computer to remove.
Remove the eight screws from the access panel.
  • Remove the eight screws from the access panel.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
  • Lift the edge of the access panel that is closest to the center of the computer.
Remove the access panel.
  • Remove the access panel.
If applicable, remove the top memory module by using your fingertips to carefully spread apart the securing clips on each end of the top memory module connector until the memory module pops up.
  • If applicable, remove the top memory module by using your fingertips to carefully spread apart the securing clips on each end of the top memory module connector until the memory module pops up.
Slide the memory module out of the socket.
  • Slide the memory module out of the socket.
If applicable, remove the bottom memory module by using your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
  • If applicable, remove the bottom memory module by using your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
Ligne d'arrivée
Johnathan Hammond
Membre depuis le 28/02/2018
33 511 Réputation
412 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
857 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 6
