Aller au contenu principal
Wahl Chrome Pro Motor Replacement
Ce dont vous avez besoin
  1. Wahl Chrome Pro Motor Replacement, Case: étape 1, image 1 de 1
    • Remove the two 5.0 mm JIS #1 screws to loosen the cutting blades.
    • Make sure your device is not connected to power before you begin.
  2. Wahl Chrome Pro Motor Replacement: étape 2, image 1 de 1
    • Lift the bottom blade straight up from the device body to remove it.
  3. Wahl Chrome Pro Motor Replacement: étape 3, image 1 de 1
    • Remove the three 9.0 mm JIS #1 screws attaching the base of the blade assembly to the body.
  4. Wahl Chrome Pro Motor Replacement: étape 4, image 1 de 1
    • Lift the base of blade assembly straight up off of the body.
  5. Wahl Chrome Pro Motor Replacement: étape 5, image 1 de 1
    • Remove the two 12.0 mm JIS #1 screws on the back of the device body.
  6. Wahl Chrome Pro Motor Replacement: étape 6, image 1 de 1
    • Remove the 13.0 mm Phillips #2 screw on the side of the device body.
    • This screw is located on the opposite side of the body from the switch.
  7. Wahl Chrome Pro Motor Replacement: étape 7, image 1 de 1
    • Remove the spring on the side of the body using tweezers.
  8. Wahl Chrome Pro Motor Replacement: étape 8, image 1 de 1
    • Pry the body case off of the device using a spudger.
  9. Wahl Chrome Pro Motor Replacement, Motor: étape 9, image 1 de 1
    • Lift power cord tab (black wire) from slot on motor base.
  10. Wahl Chrome Pro Motor Replacement: étape 10, image 1 de 1
    • Lift switch tab (teal wire) from slot on motor base.
  11. Wahl Chrome Pro Motor Replacement: étape 11, image 1 de 1
    • Remove two 23.0 mm JIS #1 screws attaching motor base to device body.
  12. Wahl Chrome Pro Motor Replacement: étape 12, image 1 de 1
    • Lift motor base straight up from device body to remove.
2 autres ont terminé cette réparation.
Ashley Dale
Membre depuis le 11/09/17
285 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S7-G3, Baechle Fall 2017 Membre de l'équipe IUPUI, Team S7-G3, Baechle Fall 2017
IUPUI-BAECHLE-F17S7G3
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 1,237
