Introduction
The power switch connects the device motor to the power cord. If the power switch becomes broken or worn, the device may not function properly.
Remove the two 5.0 mm JIS #1 screws to loosen the cutting blades.
  • Remove the two 5.0 mm JIS #1 screws to loosen the cutting blades.
  • Make sure your device is not connected to power before you begin.
Ajouter un commentaire
Lift the bottom blade straight up from the device body to remove it.
  • Lift the bottom blade straight up from the device body to remove it.
Remove the three 9.0 mm JIS #1 screws attaching the base of the blade assembly to the body.
  • Remove the three 9.0 mm JIS #1 screws attaching the base of the blade assembly to the body.
Lift the base of blade assembly straight up off of the body.
  • Lift the base of blade assembly straight up off of the body.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the two 12.0 mm JIS #1 screws on the back of the device body.
  • Remove the two 12.0 mm JIS #1 screws on the back of the device body.
Remove the 13.0 mm Phillips #2 screw on the side of the device body.
  • Remove the 13.0 mm Phillips #2 screw on the side of the device body.
    • This screw is located on the opposite side of the body from the switch.
Remove the spring  on the side of the body using tweezers.
  • Remove the spring on the side of the body using tweezers.
Pry the body case off of the device using a spudger.
  • Pry the body case off of the device using a spudger.
Remove one 7.5 mm JIS #1 screw connecting the power cord to the switch base.
  • Remove one 7.5 mm JIS #1 screw connecting the power cord to the switch base.
Remove one 7.5 mm JIS #1 screw connecting the wire to the switch base.
  • Remove one 7.5 mm JIS #1 screw connecting the wire to the switch base.
Remove the switch from device by lifting straight up from the device body.
  • Remove the switch from device by lifting straight up from the device body.
Holly Dunn
Membre depuis le 09/11/2017
101 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S7-G3, Baechle Fall 2017 Membre de l'équipe IUPUI, Team S7-G3, Baechle Fall 2017
IUPUI-BAECHLE-F17S7G3
3 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 7
Total : 62
