Pièces
Aucune pièce nécessaire.
Begin by removing the rubber grip along the handle.
  • Begin by removing the rubber grip along the handle.
Ajouter un commentaire
Remove the screws from the top to take the metal piece and plastic part off.
  • Remove the screws from the top to take the metal piece and plastic part off.
Pry open the plastic cover into two separate pieces. The plastic is very durable so don't worry about breaking it upon prying it open.
  • Pry open the plastic cover into two separate pieces. The plastic is very durable so don't worry about breaking it upon prying it open.
it doesn’t show any detail like the spring location
kglenhunter - Réponse
Here is the final result. This gives access to the switch button, chip set, battery and motor.
  • Here is the final result. This gives access to the switch button, chip set, battery and motor.
Remove the chip set, motor and battery from the plastic body. This photo shows the motor and wires connecting it to the battery.
  • Remove the chip set, motor and battery from the plastic body. This photo shows the motor and wires connecting it to the battery.
Remove the white plastic cover over the chip set allowing the battery to be taken off.
  • Remove the white plastic cover over the chip set allowing the battery to be taken off.
Remove the Lithium Ion Battery and replace it with the new one that you purchased.
  • Remove the Lithium Ion Battery and replace it with the new one that you purchased.
This battery has stamped terminals that are soldered to the PCB. Additional steps and tools need to be added to reflect the soldering work that needs to be done to replace this battery.
bob.schwenkler - Réponse
Agreed. The battery for my Wahl also has stamped terminals soldered to the PCB. I wish battery replacement for mine were as easy as the one reflected here.
Poe Larity - Réponse
Wifes Wahl Sterling trimmer (similar) got dropped and broke the negative tab In half which is also stamped to the battery as mentioned above. Easy resolder job.
Sam Houston - Réponse
I would like to know where you find the replacement battery ? I havent opened the trimmer as of yet so i have no idea plus after searching a whole entire day i found nothing and 1 battery seller mentioned to call Wahl then i found this site that mentions how easy it is to solder, well i wouldnt know cause so far the replacement battery must be a secret.
Jetro Pepper - Réponse
9 autre(s) ont terminé cette réparation.
nathan
Membre depuis le 22/10/2013
1 150 Réputation
6 tutoriels rédigés
Équipe
University of Maryland, Team 1-3, Shastany Fall 2013 Membre de l'équipe University of Maryland, Team 1-3, Shastany Fall 2013
UMD-SHASTANY-F13S1G3
3 membres
6 tutoriels rédigés
10 commentaires
Great guide but I made the mistake of buying just a standard 3.7v 750mAh battery to try and fit into the trimmer. The battery in the trimmer has metal terminals "stamped" to each end, so the terminals can't be unsoldered from the battery. I was hoping to just unsolder the existing battery and then solder in the new one but no such luck. New trimmer for me now lol
Dean Miller - Réponse
DM, I used a dremel tool with a thin grinding wheel to cut off the metal terminals just below the stamp point. After cutting off the metal terminals below the stamp point, approximately 1/4" inch of the terminals still remained which was just enough to connect the new battery to the remaining metal terminals with a small dab of solder. Little bit more work than I was anticipating but the trimmer works like new again. Found the 3.7v 750mAh battery at onlybatteries.com for $5 plus about $5.94 for shipping. Hope this helps for you DIYers!!
Dean Lamborn, 10/25/2015
Dean Lamborn - Réponse
Is it an 18650 size?
David Drasser -
To Nathan, DM and DL, I was with Nathan until I read about soldering a dremel (which i I own) and cutting off the metal terminals below the stamp point. Can any of you fine 'fixers' show pictures along with the soldering, dremel, cutting, terminals description? I want my Chromado to work like new too! Thanks in advance, Ka
Ka - Réponse
I couldnt get the button section off, i didnt know the rubber button grommet comes out and there is a single screw holding this on, it comes off easy after that. then there are two screws hidden undernearth it and it comes apart nice and easy.
Chris Dowling - Réponse
Just to add - there was no need to remove or trim the existing battery tags. Use needle-nose pliers and gently pry them off. The welding joints should peel away leaving behind the tags which you can use against your existing battery :)
Yasin Abbas - Réponse
For those looking I think you can put your money on
http://www.batteryspace.com/lithium-ncm-...
Anon Amous - Réponse
I found AA size 3.7v 750mAh Lion battery with tabs, on onlybatteries.com for $5.29 but shipping was $7.50 which is a rip off, but I went ahead and ordered because I hate to toss out a perfectly good clipper with a bad battery when it seems to be fairly easy to replace.
Alan Nevermind - Réponse
Battery came today. It took me 20 minutes to change it. My clipper is a little newer, it has a rubber grip, slide the rubber grip off carefully as not to tear it, there are 3 tabs on each side, carefully pry with a screwdriver and the 2 halves come apart. The rest is exactly as above the battery came with tabs, use a solder iron and solder removal tool to in solder the old battery, and replace with the new one careful to mind the polarity. Bend the tabs and solder in place. Snap it back together, slip the rubber grip back on, and good as new.
Voir les statistiques:
Dernières 24 heures : 31
7 derniers jours : 197
30 derniers jours : 892
Total : 29,764
