Introduction
The back panel located on the underside of the burner and is held in place by multiple screws. Take care when removing the screws as it may require a good amount of force if the panel has never been removed.
Pièces
Aucune pièce nécessaire.
Remove the screws on the back panel with the #1 Phillips screwdriver bit.
  • Remove the screws on the back panel with the #1 Phillips screwdriver bit.
    • The screws in the rubber legs of the burner do not need to be removed.
    • If the back panel has never been opened before, the screws may be more difficult to unscrew.
Ajouter un commentaire
Using a wrench, remove the bolt from the center of the back panel. Using a wrench, remove the bolt from the center of the back panel.
  • Using a wrench, remove the bolt from the center of the back panel.
The back panel can now be easily lifted off.
  • The back panel can now be easily lifted off.
Sun Fai Lau
Membre depuis le 22/09/2014
513 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 10-7, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 10-7, Brown Fall 2014
USFT-BROWN-F14S10G7
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 128
