Aller au contenu principal
Washing Machine Disassembly to Access Water Drain Pump
Ce dont vous avez besoin
  1. Washing Machine Disassembly to Access Water Drain Pump, Safety precautions: étape 1, image 1 de 2 Washing Machine Disassembly to Access Water Drain Pump, Safety precautions: étape 1, image 2 de 2
    • UNPLUG POWER CORD; TURN OFF WATER SUPPLY.
    • Check machine details on the inside of the main door.
  2. Washing Machine Disassembly to Access Water Drain Pump, Remove top cover: étape 2, image 1 de 3 Washing Machine Disassembly to Access Water Drain Pump, Remove top cover: étape 2, image 2 de 3 Washing Machine Disassembly to Access Water Drain Pump, Remove top cover: étape 2, image 3 de 3
    • Move washing machine away from wall to make rear and front accessible.
    • Using Torx T20, unscrew two screws (top left and top right on rear side) .
    • Slide top backwards, lift it off, and put it aside.
  3. Washing Machine Disassembly to Access Water Drain Pump, Remove detergent dispensing tray, and 3 screws: étape 3, image 1 de 2 Washing Machine Disassembly to Access Water Drain Pump, Remove detergent dispensing tray, and 3 screws: étape 3, image 2 de 2
    • Push down blue part in the middle to release the tray, and pull it out completely.
    • Unscrew three T20 screws; the one on the lower right is shorter.
  4. Washing Machine Disassembly to Access Water Drain Pump, Remove control panel: étape 4, image 1 de 3 Washing Machine Disassembly to Access Water Drain Pump, Remove control panel: étape 4, image 2 de 3 Washing Machine Disassembly to Access Water Drain Pump, Remove control panel: étape 4, image 3 de 3
    • Unhook three hooks at the top (two shown).
    • On the inside, on the right, there is another hook (marked), sitting between two guiding notches without hooks.
  5. Washing Machine Disassembly to Access Water Drain Pump, Disconnect control panel: étape 5, image 1 de 3 Washing Machine Disassembly to Access Water Drain Pump, Disconnect control panel: étape 5, image 2 de 3 Washing Machine Disassembly to Access Water Drain Pump, Disconnect control panel: étape 5, image 3 de 3
    • Release the cables by gently pressing the hooked guides. Note that the black part (marked by a rectangle) must be unlocked.
    • Finally, unlock the connector (e.g. with your nails or a flat-blade screwdriver) and pull it out.
    • Put the control panel aside.
  6. Washing Machine Disassembly to Access Water Drain Pump, Immobilize the tumbler unit: étape 6, image 1 de 1
    • The tumbler unit is freely suspended. Wedge a towel on the rear side behind the tumbler unit to immobilize it. This will prevent damage when tilting the washing machine later on.
    • DO NOT FORGET TO REMOVE THIS when reassembling!
  7. Washing Machine Disassembly to Access Water Drain Pump, Detach door seal from front cover: étape 7, image 1 de 3 Washing Machine Disassembly to Access Water Drain Pump, Detach door seal from front cover: étape 7, image 2 de 3 Washing Machine Disassembly to Access Water Drain Pump, Detach door seal from front cover: étape 7, image 3 de 3
    • The rubber door seal is attached to the front cover by a metal wire and a spring.
    • Pry out the spring and pull away the wire.
    • Unpeel the seal all the way round, and tuck it inside.
  8. Washing Machine Disassembly to Access Water Drain Pump, Remove drain/filter door, drain water, and unscrew: étape 8, image 1 de 2 Washing Machine Disassembly to Access Water Drain Pump, Remove drain/filter door, drain water, and unscrew: étape 8, image 2 de 2
    • The round door (front bottom right) for the drain tube and filter can be removed, by opening it completely, and gently pulling out the left side of the hinge.
    • DRAIN ANY REMAINING WATER.
    • Unscrew two T20 screws.
  9. Washing Machine Disassembly to Access Water Drain Pump, Unscrew front cover: étape 9, image 1 de 3 Washing Machine Disassembly to Access Water Drain Pump, Unscrew front cover: étape 9, image 2 de 3 Washing Machine Disassembly to Access Water Drain Pump, Unscrew front cover: étape 9, image 3 de 3
    • Unscrew two (T20) screws at the top.
    • Tilt the whole washing machine towards its rear side to expose the front bottom. Lean it against a wall.
    • Unscrew two (6mm hex-head) screws on the bottom.
  10. Washing Machine Disassembly to Access Water Drain Pump, Remove front cover: étape 10, image 1 de 3 Washing Machine Disassembly to Access Water Drain Pump, Remove front cover: étape 10, image 2 de 3 Washing Machine Disassembly to Access Water Drain Pump, Remove front cover: étape 10, image 3 de 3
    • The front cover is held in place by plastic hooked pins. Slightly lift the front cover to unhook it.
    • On the inside, unclip something, and pull out a connector (for the door lock). The plastic emergency door release comes out easily. The image shows this when clip and connector are already disconnected.
    • DO NOT FORGET TO PUT ALL THIS BACK on reassembly!
  11. Washing Machine Disassembly to Access Water Drain Pump, Remove plastic strip: étape 11, image 1 de 3 Washing Machine Disassembly to Access Water Drain Pump, Remove plastic strip: étape 11, image 2 de 3 Washing Machine Disassembly to Access Water Drain Pump, Remove plastic strip: étape 11, image 3 de 3
    • Remove the plastic strip that protects the bottom edge.
    • Unhook on the back, and tilt it forwards.
    • Note the guiding notches to help you put it back.
  12. Washing Machine Disassembly to Access Water Drain Pump, Remove drain/filter cover plate: étape 12, image 1 de 3 Washing Machine Disassembly to Access Water Drain Pump, Remove drain/filter cover plate: étape 12, image 2 de 3 Washing Machine Disassembly to Access Water Drain Pump, Remove drain/filter cover plate: étape 12, image 3 de 3
    • Unscrew one (T20) screw.
    • Tilt the plate back, and lift it. There is a hooked tab, and a guiding pin to help you reassemble the plate.
    • Pull out the drain tube.
    • Put the cover plate aside.
  13. Washing Machine Disassembly to Access Water Drain Pump, Disconnect pump: étape 13, image 1 de 3 Washing Machine Disassembly to Access Water Drain Pump, Disconnect pump: étape 13, image 2 de 3 Washing Machine Disassembly to Access Water Drain Pump, Disconnect pump: étape 13, image 3 de 3
    • Pull the power connector from the pump.
    • Using pliers, loosen the clamp on the hose from the tumbler and slide it back.
    • Remove the hose.
    • BE PREPARED FOR SOME WATER (use a towel or bowl).
  14. Washing Machine Disassembly to Access Water Drain Pump, Remove debris: étape 14, image 1 de 1
    • In my case, the pump inlet (where we just removed the hose coming from the tumbler) was clogged with debris and some cloth.
    • This prevented draining, and even prevented removal of the filter. Thus, requiring disassembly. But we are not done yet.
  15. Washing Machine Disassembly to Access Water Drain Pump, Detach filter/pump unit: étape 15, image 1 de 3 Washing Machine Disassembly to Access Water Drain Pump, Detach filter/pump unit: étape 15, image 2 de 3 Washing Machine Disassembly to Access Water Drain Pump, Detach filter/pump unit: étape 15, image 3 de 3
    • Unscrew four T2 screws.
    • Tilt the filter/pump unit (note the tab at the top), and pull it out from the back.
  16. Washing Machine Disassembly to Access Water Drain Pump, Clean inlet, filter, and pump: étape 16, image 1 de 3 Washing Machine Disassembly to Access Water Drain Pump, Clean inlet, filter, and pump: étape 16, image 2 de 3 Washing Machine Disassembly to Access Water Drain Pump, Clean inlet, filter, and pump: étape 16, image 3 de 3
    • At his point you can clean the water inlet, the filter, and the pump. The propellor should move freely. The pump itself can also be removed to replace it (but I did not do that).
    • In my case, a significant amount of cloth got stuck in the water inlet, including a necklace. In the filter, there were some hairpins, and inside the pump itself, a coin and a pendent. LESSON: CLEAN THE FILTER MORE OFTEN, while you can stil remove it without disassembling the machine.
8 autres ont terminé cette réparation.
Tom Verhoeff
Membre depuis le 03/31/18
513 Réputation
1 tutoriel rédigé
4 commentaires
Perfect! It helped me to disassemble this same model to find out that our pump was jammed with a thin thread. Had to replace the pump, but that was the easy part once the machine was disassembled!
Marcel Hogenstein - Réponse
Awesome guide, many thanks Tom. Took just over an hour to have it back up and running (cleaned our pump with underwire and a cotton ball). Hardest part was that clip on the right of the sensor panel. and getting the rubber seal back on. Many thanks again!
Tony Baroona - Réponse
Fantastic. Amazing resource. Saved me so much time, money, hassle.
Found my fault, a simple disconnected pipe and re connected it.
Oliver Farrell - Réponse
Thanks Tom, what an excellent guide, really appreciate the effort you've made in creating it.
All done in under an hour, I didn't break anything and didn't end up with any screws left at the end for a change.
The hoop and spring that holds the rubber around the door was the only bit that I struggled with as it's a very, very strong spring.
Andy Mason - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 15
30 derniers jours : 89
Total : 7,117
