Aller au contenu principal
Watch Battery Replacement
Ce dont vous avez besoin
  1. Watch Battery Replacement, Battery: étape 1, image 1 de 2 Watch Battery Replacement, Battery: étape 1, image 2 de 2
    • For this project you will need the watch you are replacing the battery on, the new battery and a mini flat head screwdriver.
  2. Watch Battery Replacement: étape 2, image 1 de 3 Watch Battery Replacement: étape 2, image 2 de 3 Watch Battery Replacement: étape 2, image 3 de 3
    • You will need to take the back of the watch off. To do this you will turn the watch over to the back side and look carefully for a small groove opening. This is where you will use the mini flat head screwdriver. Insert the flat head screwdriver into the groove and pop the back off of the watch.
  3. Watch Battery Replacement: étape 3, image 1 de 2 Watch Battery Replacement: étape 3, image 2 de 2
    • Take the white plastic ring out of the watch. You can use the mini flat head screwdriver or your finger to pull it out.
  4. Watch Battery Replacement: étape 4, image 1 de 3 Watch Battery Replacement: étape 4, image 2 de 3 Watch Battery Replacement: étape 4, image 3 de 3
    • Take the old battery out of the watch. You can use the mini flat head screwdriver to do this.
  5. Watch Battery Replacement: étape 5, image 1 de 1
    • Put the new battery in watch. Use your fingers to insert the new battery.
  6. Watch Battery Replacement: étape 6, image 1 de 1
    • Use your fingers to insert the plastic white ring back into the watch.
  7. Watch Battery Replacement: étape 7, image 1 de 1
    • Put the back of the watch on using your fingers. Press down so that you hear a snap to ensure the back is on properly.
  8. Watch Battery Replacement: étape 8, image 1 de 1
    • You are all done and can now set the time on your watch.
  9. Watch Battery Replacement: étape 9, image 1 de 2 Watch Battery Replacement: étape 9, image 2 de 2
    • When you are not using the watch, pull the pin out to stop the watch from running
  10. Watch Battery Replacement: étape 10, image 1 de 1
    • When the pin is pulled out, the battery is not being used. Only push the pin in and set the time when you are using the watch. This will preserve the life of your new battery.
9 autres ont terminé cette réparation.
TIMONTE HUNTER
Membre depuis le 03/02/16
391 Réputation
1 tutoriel rédigé
Équipe
Pasco Hernando, Team 5-10, Prince Winter 2016 Membre de l'équipe Pasco Hernando, Team 5-10, Prince Winter 2016
PHSC-PRINCE-W16S5G10
2 membres
2 tutoriels rédigés
6 commentaires
First time I have done this and I have somehow lost the white plastic! Is this essential?
barbaramcraig - Réponse
Yes. I can’t get the plastic spacer back in right. I guess that is why I can’t get the back.
jybentneedle48 - Réponse
I'm trying to figure out the type of watch that is can anyone help me that? This is the only place I can find an image of it. I recently purchased it private sale and they couldn't remember.
karmstrong20112012 - Réponse
Googling the model number on the back, LDC74709W, leads me to believe it’s an unbranded watch that was sold at Walmart in the past.
Austin Blakely -
What is the battery number
David Corley - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 12
7 derniers jours : 94
30 derniers jours : 394
Total : 49,888
