Introduction
Tearing down my door alarm to see what's broken - it should beep hard but it isn't. It's a pretty fragile thing that could use some new fixation. (I didn't photograph the magnet that's next to it but it exists and the alarm stops when it is close to the device).
Pièces
Aucune pièce nécessaire.
This is a beautiful not-alarming alarm This is a beautiful not-alarming alarm
  • This is a beautiful not-alarming alarm
Ajouter un commentaire
There is a screw hidden underneath the adhesive strip. Screw it open to get in
  • There is a screw hidden underneath the adhesive strip. Screw it open to get in
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the batteries so you won't frighten yourself by a suddenly-working alarm (or break the alarm) Remove the batteries so you won't frighten yourself by a suddenly-working alarm (or break the alarm)
  • Remove the batteries so you won't frighten yourself by a suddenly-working alarm (or break the alarm)
The wires weren't soldered good enough to make a sound. I applied a bit of fresh solder on the indicated places to make it work again The wires weren't soldered good enough to make a sound. I applied a bit of fresh solder on the indicated places to make it work again
  • The wires weren't soldered good enough to make a sound. I applied a bit of fresh solder on the indicated places to make it work again
  • This will definitely wake me up when there's someone opening my door! Fixed
Anke
Membre depuis le 25/04/2018
122 Réputation
1 tutoriel rédigé
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 21
