Aller au contenu principal
N-Strike Nite Finder EX-3 Wire Replacement Guide
Ce dont vous avez besoin
  1. N-Strike Nite Finder EX-3 Wire Replacement Guide, Wire: étape 1, image 1 de 1
    • Place the blaster upside down on the table, and remove the screw in the bottom of the handle.
    • Remove the battery door and take the batteries out.
  2. N-Strike Nite Finder EX-3 Wire Replacement Guide: étape 2, image 1 de 3 N-Strike Nite Finder EX-3 Wire Replacement Guide: étape 2, image 2 de 3 N-Strike Nite Finder EX-3 Wire Replacement Guide: étape 2, image 3 de 3
    • Set the blaster on its side with the screws facing up (the blaster will be placed on its left side). Remove all 14 phillips head, 8.2 mm screws and set them aside.
    • Lift the side of the blaster to expose its internal parts.
  3. N-Strike Nite Finder EX-3 Wire Replacement Guide: étape 3, image 1 de 1
    • Visually inspect all the wires in order to find the break, fray, or any other problem.
    • Locate the end connections of the affected wire.
  4. N-Strike Nite Finder EX-3 Wire Replacement Guide: étape 4, image 1 de 1
    • Use a hot soldering iron to melt the solder at one end of the wire until the wire can be pulled free from the connection.
    • Repeat on the other end of the connection to remove the wire from the blaster.
    • (End points marked on image are for the black wire)
Kyle Schober
Membre depuis le 02/24/14
640 Réputation
5 tutoriels rédigés
Équipe
Michigan Tech, Team 5-8, Lauer Spring 2014 Membre de l'équipe Michigan Tech, Team 5-8, Lauer Spring 2014
MTU-LAUER-S14S5G8
3 membres
13 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 4
Total : 913
