Aller au contenu principal
XQ-673H Water Tubes Replacement
Ce dont vous avez besoin
  1. XQ-673H Water Tubes Replacement, Water Tubes: étape 1, image 1 de 1
    • Make sure the device is unplugged before continuing.
    • Turn the Kitchen Gourmet upside down.
  2. XQ-673H Water Tubes Replacement: étape 2, image 1 de 3 XQ-673H Water Tubes Replacement: étape 2, image 2 de 3 XQ-673H Water Tubes Replacement: étape 2, image 3 de 3
    • Using a Phillips #1 screwdriver, remove the six 10mm screws found on the bottom of the device.
    • Remove the bottom cover.
  3. XQ-673H Water Tubes Replacement: étape 3, image 1 de 2 XQ-673H Water Tubes Replacement: étape 3, image 2 de 2
    • Using a Phillips #1 screwdriver, remove the six 12mm screws.
    • Some screws are not visible from this photo, but their location is highlighted by the circles.
  4. XQ-673H Water Tubes Replacement: étape 4, image 1 de 3 XQ-673H Water Tubes Replacement: étape 4, image 2 de 3 XQ-673H Water Tubes Replacement: étape 4, image 3 de 3
    • Using small needle nose pliers, squeeze the metal that is covering the tube.
    • Carefully slide down the metal covering.
    • Repeat this step for the other tube.
  5. XQ-673H Water Tubes Replacement: étape 5, image 1 de 2 XQ-673H Water Tubes Replacement: étape 5, image 2 de 2
    • Using your fingers, gently slide off the Water Tubes.
  6. XQ-673H Water Tubes Replacement: étape 6, image 1 de 2 XQ-673H Water Tubes Replacement: étape 6, image 2 de 2
    • Carefully lift the bottom section off the device.
  7. XQ-673H Water Tubes Replacement: étape 7, image 1 de 2 XQ-673H Water Tubes Replacement: étape 7, image 2 de 2
    • Remove both of the Water Tubes completely.
Sean Perry
Membre depuis le 01/31/15
425 Réputation
4 tutoriels rédigés
Équipe
USF Sarasota-Manatee, Team 1-3, Stewart Winter 2015 Membre de l'équipe USF Sarasota-Manatee, Team 1-3, Stewart Winter 2015
USFSM-STEWART-W15S1G3
4 membres
14 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 13
Total : 725
