Introduction
Make your Xbox 360 S look shiny and new by replacing the outer panels.
Orient the Xbox 360 S so that the bottom of the console is facing toward you. Push the latch holding down the hard drive cover to the left. Pull the hard drive cover away from the console.
  • Orient the Xbox 360 S so that the bottom of the console is facing toward you.
  • Push the latch holding down the hard drive cover to the left.
  • Pull the hard drive cover away from the console.
Ajouter un commentaire
Firmly grasp the fabric tab labeled "250 GB" attached to the hard drive. Pull the hard drive straight out of the console. The fabric tab is attached to a catch further inside the hard drive housing. It will take some force to pull the hard drive out.
  • Firmly grasp the fabric tab labeled "250 GB" attached to the hard drive.
  • Pull the hard drive straight out of the console.
  • The fabric tab is attached to a catch further inside the hard drive housing. It will take some force to pull the hard drive out.
If i buy a new xbox 360 and replace the hardrive inside with my own, will i have my account and saves? or will i have to recover my account and start over?
yamboboy - Réponse
You will still have your saves and account if you replace your hard drive in the new xbox
Robert Miller -
hola tengo un disco de laptop y quiero ponerle 100 juegos como puedo hacer la xbox me reconose el disco y todo lo configuro pero cuando conecto a mi pc para pasar los juejosel emulador no me deja
Cesar Tourreilles - Réponse
In the following steps, you will remove the bottom vent.
  • In the following steps, you will remove the bottom vent.
    • It is attached to the bottom panel by the seven clips shown.
Orient the Xbox 360 S so that the hard drive port is facing up and the faceplate is facing to the left. Insert a metal spudger between the black bottom vent and the silver rim of the bottom bezel, in the rear right corner of the vent.
  • Orient the Xbox 360 S so that the hard drive port is facing up and the faceplate is facing to the left.
  • Insert a metal spudger between the black bottom vent and the silver rim of the bottom bezel, in the rear right corner of the vent.
  • Rotate the spudger away from the console, prying the vent up from the bottom bezel.
  • Be sure to rotate the spudger far enough so that the clips on the vent are lifted past the silver rim of the bottom bezel.
In the same manner as described above, pry the two remaining clips on the bottom right edge. All of the clips along both the right and front edge should now be free. If other clips have come undone as well, that is fine. All of the clips along both the right and front edge should now be free. If other clips have come undone as well, that is fine.
  • In the same manner as described above, pry the two remaining clips on the bottom right edge.
  • All of the clips along both the right and front edge should now be free. If other clips have come undone as well, that is fine.
Remove the bottom vent by lifting it away from the bottom bezel. Remove the bottom vent by lifting it away from the bottom bezel.
  • Remove the bottom vent by lifting it away from the bottom bezel.
In the following steps, you will remove the bottom bezel, which is attached to the rest of the console by the six clips shown. The clips shown in red can be detached by inserting a metal spudger underneath the bottom edge of the clip. Once underneath the bottom edge, simply prying away from the console will free the clip.
  • In the following steps, you will remove the bottom bezel, which is attached to the rest of the console by the six clips shown.
  • The clips shown in red can be detached by inserting a metal spudger underneath the bottom edge of the clip. Once underneath the bottom edge, simply prying away from the console will free the clip.
Insert a metal spudger through the slit near the rear left corner of the bottom bezel. Rotate the spudger away from the device while lifting the rear bezel up with the other hand.
  • Insert a metal spudger through the slit near the rear left corner of the bottom bezel.
  • Rotate the spudger away from the device while lifting the rear bezel up with the other hand.
  • You may hear a "pop" signifying the clip has cleared its catch.
Insert a metal spudger through the left middle slit of the bottom bezel, and between the bottom edge of the clip and the left case. Simultaneously pull the bottom bezel up and rotate the spudger away from the console to free the clip.
  • Insert a metal spudger through the left middle slit of the bottom bezel, and between the bottom edge of the clip and the left case.
  • Simultaneously pull the bottom bezel up and rotate the spudger away from the console to free the clip.
  • In a similar fashion, free the clip at the front of the bottom bezel's left edge.
  • The entire left side of the bottom bezel should now be free.
Turn the console around so that the faceplate is facing to the right and the right case is facing toward you. Insert the spudger into the rear-most slit on the right edge of the bottom bezel, and wedge it behind the clip by pushing the spudger down while pushing the tip of the spudger against the right case.
  • Turn the console around so that the faceplate is facing to the right and the right case is facing toward you.
  • Insert the spudger into the rear-most slit on the right edge of the bottom bezel, and wedge it behind the clip by pushing the spudger down while pushing the tip of the spudger against the right case.
  • Simultaneously release the clip and pull the bottom bezel up.
  • This clip is especially hard to remove. Some force will be required to insert the spudger correctly.
This clip does not have a slit in the bezel to guide you.  You can locate the clip by looking under the bezel near the hard drive slot.
  • This clip does not have a slit in the bezel to guide you. You can locate the clip by looking under the bezel near the hard drive slot.
  • Insert a spudger between the silver rim and bottom bezel directly above the clip shown.
  • Release the clip while pulling up on the bottom bezel.
This clip is smaller than the others and should not be removed from above like the others. Lift the left edge of the bottom bezel up enough to gain clearance.
  • This clip is smaller than the others and should not be removed from above like the others.
  • Lift the left edge of the bottom bezel up enough to gain clearance.
  • Insert a metal spudger behind the left edge of the last clip, and push the clip away from the right case.
42 autre(s) ont terminé cette réparation.
Matthew Newsom
Membre depuis le 05/01/2010
31 477 Réputation
93 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 7
7 derniers jours : 23
30 derniers jours : 87
Total : 45,104
