Aller au contenu principal
Xbox 360 S Wi-Fi Board Replacement
Ce dont vous avez besoin
  1. Xbox 360 S Wi-Fi Board Replacement, Top Panel: étape 1, image 1 de 1
    • In the following steps, you will remove the top vent, secured to the top panel by the thirteen clips shown.
    • Take care when removing the fan vent not to break any of the plastic clips.
  2. Xbox 360 S Wi-Fi Board Replacement: étape 2, image 1 de 2 Xbox 360 S Wi-Fi Board Replacement: étape 2, image 2 de 2
    • Orient the console so that the words "XBOX 360" on the sides are right-side up, and the faceplate is facing to the left.
    • Insert a metal spudger between the top vent and the top bezel near the rear of the Xbox.
    • Rotate the spudger away from the console, prying the edge of the fan vent up until the two plastic clips come free.
    • Be sure to rotate the spudger far enough so that the plastic clips clear the silver rim of the top bezel.
  3. Xbox 360 S Wi-Fi Board Replacement: étape 3, image 1 de 3 Xbox 360 S Wi-Fi Board Replacement: étape 3, image 2 de 3 Xbox 360 S Wi-Fi Board Replacement: étape 3, image 3 de 3
    • Insert a metal spudger between the fan vent and top bezel along the left side of the console.
    • In the same manner described above, begin prying the left side of the top vent away from the top bezel.
    • Continue prying along the left side of the device, freeing all the clips on that side.
  4. Xbox 360 S Wi-Fi Board Replacement: étape 4, image 1 de 2 Xbox 360 S Wi-Fi Board Replacement: étape 4, image 2 de 2
    • Lift the fan vent up from the freed left side to disengage the clips along the right side.
    • Remove the entire fan vent.
  5. Xbox 360 S Wi-Fi Board Replacement: étape 5, image 1 de 2 Xbox 360 S Wi-Fi Board Replacement: étape 5, image 2 de 2
    • In the following steps, you will be releasing the six clips highlighted in red.
    • Each clip can be undone by inserting a metal spudger underneath the bottom edge of the clip. Once underneath the bottom edge, simply prying away from the console will free the clip.
  6. Xbox 360 S Wi-Fi Board Replacement: étape 6, image 1 de 2 Xbox 360 S Wi-Fi Board Replacement: étape 6, image 2 de 2
    • Orient the console so that the left case is facing toward you and the faceplate is facing toward the right.
    • Insert a metal spudger through the front-most slit on the left edge of the top bezel and between the bottom edge of the clip and the left case, as described above.
    • Simultaneously rotate the spudger away from the console and pull up on the top bezel to free the clip.
    • You will hear a "pop" signifying that the clip cleared its catch.
  7. Xbox 360 S Wi-Fi Board Replacement: étape 7, image 1 de 2 Xbox 360 S Wi-Fi Board Replacement: étape 7, image 2 de 2
    • Using the same method described above, free the two remaining clips along the left edge of the top bezel.
  8. Xbox 360 S Wi-Fi Board Replacement: étape 8, image 1 de 1
    • Grab the entire top panel with your hands, lift up the entire left edge high enough to rest the separated clips on top of the left case.
    • You may have to go back with a spudger and undo any clips that have re-attached.
    • The top panel will not come free of the console yet.
  9. Xbox 360 S Wi-Fi Board Replacement: étape 9, image 1 de 2 Xbox 360 S Wi-Fi Board Replacement: étape 9, image 2 de 2
    • Rotate the console so that the rear of the Xbox 360 S is facing to the right, and the right case is facing you.
    • Insert a metal spudger through the rear-most slit on the right edge of the top bezel and between the bottom edge of the clip and the right case.
    • While lifting up on the top bezel with your fingers, rotate the spudger away from the console to free the clip.
  10. Xbox 360 S Wi-Fi Board Replacement: étape 10, image 1 de 2 Xbox 360 S Wi-Fi Board Replacement: étape 10, image 2 de 2
    • In the same manner as described in the previous steps, release the middle and front clips along the right edge of the top panel.
  11. Xbox 360 S Wi-Fi Board Replacement: étape 11, image 1 de 1
    • Lift the top panel off the device.
    • You may have to go back with a spudger and undo any clips that have re-attached to the console.
  12. Xbox 360 S Wi-Fi Board Replacement, Wi-Fi Board: étape 12, image 1 de 3 Xbox 360 S Wi-Fi Board Replacement, Wi-Fi Board: étape 12, image 2 de 3 Xbox 360 S Wi-Fi Board Replacement, Wi-Fi Board: étape 12, image 3 de 3
    • Remove the single T10 Torx screw holding in the wireless card.
    • Pull the Wi-Fi board out of the console.
37 autres ont terminé cette réparation.
Brett Hartt
Membre depuis le 04/12/10
127 941 Réputation
143 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
136 membres
17 298 tutoriels rédigés
4 commentaires
My Slim came without the wifi board, and subsequently without the holding screw.
Anyone know the thread, size, or depth of a replacement screw I could use to hold the replacement in? It seems like it won't go anywhere with the pseudo-USB connector in place, but I'd like to be positive.
Any help would be appreciated!
mattinnihon - Réponse
Tuve ese mismo problema. Fui a una tienda y el técnico tuvo que quitarle la tarjeta de WiFi a otro xbox porque no hay repuesto
andreshgarcia20 - Réponse
Worth noting.. Before you purchase a new wifi card, try taking it out and reseating it. Just had to do that with mine when the wifi suddenly stopped working. Once I pulled the card and put it back in, it worked beautifully.
Also, for clarification, you are opening the side OPPOSITE the side with the hard drive.
sarncadrill - Réponse
Is it possible to replace it a newer, updated, improved WiFi card that is faster?
NoraTheSuccubus - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 28
30 derniers jours : 192
Total : 55,864
