Aller au contenu principal
Xbox 360 Wireless Controller Triggers Replacement
Ce dont vous avez besoin
  1. Xbox 360 Wireless Controller Triggers Replacement, Battery: étape 1, image 1 de 2 Xbox 360 Wireless Controller Triggers Replacement, Battery: étape 1, image 2 de 2
    • Depress the battery release button on the top of the controller.
    • Remove the battery holder from the controller.
    • The standard option for Xbox 360 Wireless Controllers Battery Packs is AA batteries. A rechargeable battery is also available, but both battery options are removed from the controller in the same way.
  2. Xbox 360 Wireless Controller Triggers Replacement, Rear Case: étape 2, image 1 de 1
    • Use a pair of tweezers to peel the barcode sticker from the battery compartment.
  3. Xbox 360 Wireless Controller Triggers Replacement: étape 3, image 1 de 1
    • Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
  4. Xbox 360 Wireless Controller Triggers Replacement: étape 4, image 1 de 2 Xbox 360 Wireless Controller Triggers Replacement: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    Spudger
    $2.99
    J'achète
    • Insert a Spudger between the front and rear cases along the left edge of the controller.
    • Rotate the spudger toward the front of the controller, prying the two cases apart.
  5. Xbox 360 Wireless Controller Triggers Replacement: étape 5, image 1 de 2 Xbox 360 Wireless Controller Triggers Replacement: étape 5, image 2 de 2
    • Insert a spudger between the front and rear cases, near the headphone jack.
    • Rotate the spudger toward the front of the controller to pry the two cases apart.
  6. Xbox 360 Wireless Controller Triggers Replacement: étape 6, image 1 de 2 Xbox 360 Wireless Controller Triggers Replacement: étape 6, image 2 de 2
    • Grasp the controller by the battery compartment and the headphone jack.
    • Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
    • The battery contact springs are held in place by slots in the battery housing in the rear case. Be sure to realign them properly during reassembly.
  7. Xbox 360 Wireless Controller Triggers Replacement, Vibration Motors: étape 7, image 1 de 2 Xbox 360 Wireless Controller Triggers Replacement, Vibration Motors: étape 7, image 2 de 2
    • Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
    • Lift the vibration motor out of the front case.
  8. Xbox 360 Wireless Controller Triggers Replacement: étape 8, image 1 de 2 Xbox 360 Wireless Controller Triggers Replacement: étape 8, image 2 de 2
    • Remove the vibration motor from the other side of the controller using the same method previously described.
    • The left motor has significantly more counterweight than the right motor.
  9. Xbox 360 Wireless Controller Triggers Replacement, Logic Board: étape 9, image 1 de 2 Xbox 360 Wireless Controller Triggers Replacement, Logic Board: étape 9, image 2 de 2
    • Lifting from the headphone jack and power plug, remove the logic board from the front case.
  10. Xbox 360 Wireless Controller Triggers Replacement, Triggers: étape 10, image 1 de 3 Xbox 360 Wireless Controller Triggers Replacement, Triggers: étape 10, image 2 de 3 Xbox 360 Wireless Controller Triggers Replacement, Triggers: étape 10, image 3 de 3
    • Using your thumb and forefinger, push the left trigger toward the right side of the controller. Simultaneously push the trigger control arm in the opposite direction.
    • The trigger has a peg that fits into a slot in the trigger arm. Be sure to push far enough so that the peg clears the slot.
    • Push the trigger arm downward.
  11. Xbox 360 Wireless Controller Triggers Replacement: étape 11, image 1 de 3 Xbox 360 Wireless Controller Triggers Replacement: étape 11, image 2 de 3 Xbox 360 Wireless Controller Triggers Replacement: étape 11, image 3 de 3
    • Insert the edge of a spudger in between the trigger and the trigger assembly near the left edge. Pry the housing away from the catch on the trigger.
    • Using the previously described technique, pry the housing on the right edge away from the trigger.
    • Rotate the trigger away from the logic board, past its housing.
  12. Xbox 360 Wireless Controller Triggers Replacement: étape 12, image 1 de 3 Xbox 360 Wireless Controller Triggers Replacement: étape 12, image 2 de 3 Xbox 360 Wireless Controller Triggers Replacement: étape 12, image 3 de 3
    • Using a spudger, pry the trigger spring off its peg on the trigger housing.
    • Pull the trigger spring out of the trigger.
  13. Xbox 360 Wireless Controller Triggers Replacement: étape 13, image 1 de 3 Xbox 360 Wireless Controller Triggers Replacement: étape 13, image 2 de 3 Xbox 360 Wireless Controller Triggers Replacement: étape 13, image 3 de 3
    • Slide the trigger toward the right side of the logic board, and rotate it clockwise.
    • Remove the right trigger from the logic board.
    • To remove the left trigger from the logic board, follow the procedure previously described for the right trigger.
45 autres ont terminé cette réparation.
Brett Hartt
Membre depuis le 04/12/10
127 897 Réputation
143 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 817 tutoriels rédigés
5 commentaires
use a small tag of double sided tape to hold the counterweights in when you rebuild or its nearly impossible to tip up the two halfs of the controller to fit them together. With the counterweight just slightly stuck into place with a tiny tag of double sided tape you can tip that half of the controller upside down to fit on top of the other half. Still awkward but do-able. Almost impossible otherwise.
iorigrif - Réponse
If i leave out the vibrations things will it cause the problems tonthe board ??
Michael Francis - Réponse
These instructions were given in proper order and understanding
Arthur Murray Doan - Réponse
IMO this could have benefited from some instructions on how to get the triggers back on, cause it was quite a challenge.
The way I managed to do it, is you've got to reverse both step 11 and step 10 in one go, otherwise it would be impossible to get the trigger peg into the white arm (at least I couldn't figure out a way to do it): before reversing step 11, hold the white arm up and to same side you pushed it in the step 10, and then once you click it back into place, the peg would also go into the slot in the arm. For me it was easier to do for LT than RT - the latter too a few tries, so I would recommend doing LT first and then RT.
Rathori - Réponse
Left trigger on xbox 360 wireless controler not working
Rog - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 41
30 derniers jours : 203
Total : 82,981
