Aller au contenu principal
Xbox One Elite Controller (Model 1698) Daughterboard Replacement
Ce dont vous avez besoin
  1. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Show me the Screws!: étape 1, image 1 de 2 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Show me the Screws!: étape 1, image 2 de 2
    • You can remove the side panels with a pry tool.
    • You don't need to remove the rubber. The rubber on this controller was already bad
  2. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Removing the back panel screws: étape 2, image 1 de 1
    • Remove the 5 Torx Security Bit (TR9) screws
  3. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Popping that back panel off: étape 3, image 1 de 3 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Popping that back panel off: étape 3, image 2 de 3 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Popping that back panel off: étape 3, image 3 de 3
    • Pry the panel next to the 3.5mm port
    • Be careful to not rip the ribbon shown in the next step
  4. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Warning Carefully remove the ribbon: étape 4, image 1 de 2 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Warning Carefully remove the ribbon: étape 4, image 2 de 2
    • Be careful to not rip the ribbon cable
    • You can pop the connector up to remove the ribbon easily
    • Ribbon Cable
  5. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Screws on controller motherboard: étape 5, image 1 de 1
    • Remove the 2 Torx (T6) screws
  6. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Desolder wires from motherboard: étape 6, image 1 de 2 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Desolder wires from motherboard: étape 6, image 2 de 2
    • Desolder the 4 wires on each side, these control the vibrations and the RT LT
  7. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the motherboard: étape 7, image 1 de 2 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the motherboard: étape 7, image 2 de 2
    • Pull up from the "top" side of the controller on the sister board.
  8. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the Home Button Cover: étape 8, image 1 de 3 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the Home Button Cover: étape 8, image 2 de 3 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the Home Button Cover: étape 8, image 3 de 3
    • Be Careful to not lose the sync button
    • Pry the middle section up from the home button side.
    • This will also remove the LB and RB which is a single part
  9. Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the controller daughterboard: étape 9, image 1 de 2 Xbox One Elite Controller (Model 1698) Daughterboard Replacement, Remove the controller daughterboard: étape 9, image 2 de 2
    • Unscrew the 6 Torx (T6) screws
2 autres ont terminé cette réparation.
EasyAsABC123
Membre depuis le 01/22/10
2 407 Réputation
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 28
30 derniers jours : 79
Total : 8,269
