Aller au contenu principal
Xbox One Optical Drive Laser Replacement
Ce dont vous avez besoin
  1. Xbox One Optical Drive Laser Replacement, Optical Drive Case Screws: étape 1, image 1 de 1
    • Make sure the optical drive is not connected to any power source and is powered off.
    • Unscrew the four Phillips #1 screws on the top of the optical drive.
  2. Xbox One Optical Drive Laser Replacement, Optical Drive Case Lid: étape 2, image 1 de 1
    • Lift the lid off of the optical drive case, this should require little to no force.
  3. Xbox One Optical Drive Laser Replacement, Optical Drive Case: étape 3, image 1 de 2 Xbox One Optical Drive Laser Replacement, Optical Drive Case: étape 3, image 2 de 2
    • Slide the remaining optical drive case off of the internal components.
    • Internal components often snag on these points when removing the optical drive case.
  4. Xbox One Optical Drive Laser Replacement, ZIF Connectors: étape 4, image 1 de 2 Xbox One Optical Drive Laser Replacement, ZIF Connectors: étape 4, image 2 de 2
    • Locate the three ZIF connectors on the optical drive PCB.
    • Using tweezers, gently lift the tab on each ZIF connector to release the ribbon cables.
    • Remove the ribbon cable from each ZIF connector.
  5. Xbox One Optical Drive Laser Replacement, PCB Screws: étape 5, image 1 de 1
    • Unscrew the three Phillips #0 screws mounting the PCB.
  6. Xbox One Optical Drive Laser Replacement, Moving the PCB: étape 6, image 1 de 1
    • Gently lift the PCB and place it to the side.
    • When lifting the PCB, be careful to not detach the wires connecting the PCB to the motor.
  7. Xbox One Optical Drive Laser Replacement, Optical Drive Laser Screws: étape 7, image 1 de 1
    • Unscrew the three Phillips #0 screws mounting the optical drive laser.
  8. Xbox One Optical Drive Laser Replacement, Optical Drive Laser: étape 8, image 1 de 1
    • Lift the old optical drive laser from the unit and place in the new optical drive laser.
6 autres ont terminé cette réparation.
Austin Stein
Membre depuis le 02/24/21
259 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 32
30 derniers jours : 147
Total : 4,299
