Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Xbox Series X Base Replacement
Ce dont vous avez besoin
  1. Xbox Series X Base Replacement, Unlatch the base: étape 1, image 1 de 3 Xbox Series X Base Replacement, Unlatch the base: étape 1, image 2 de 3 Xbox Series X Base Replacement, Unlatch the base: étape 1, image 3 de 3
    • Before you begin, completely power down and unplug all cables from your console.
    • A locking tab on the bottom of the shell (under the base) holds the base in place.
    • You can access the tab through the vent holes on the back of your Xbox, but you may need a flashlight. Alternatively, you can remove the back panel for easier access.
    • Stick a long, skinny flathead screwdriver through one of the vent holes on the back of your Xbox, near the locking tab.
    • Insert the screwdriver between the locking tab and the base. This might take a few tries—use a flashlight if you're having trouble.
    • Use the screwdriver to pry the tab inward (away from the base) into its open and unlocked position.
    • Keep the tab held open for the next step.
    Demander à FixBot
    Ajouter un commentaire
  2. Xbox Series X Base Replacement, Twist and remove the base: étape 2, image 1 de 3 Xbox Series X Base Replacement, Twist and remove the base: étape 2, image 2 de 3 Xbox Series X Base Replacement, Twist and remove the base: étape 2, image 3 de 3
    • With the locking tab held open, grip the base and rotate it counterclockwise to unlock it from the shell.
    • Remove the base.
    • During reassembly, put the base tabs into their holes on the shell and twist clockwise until the base snaps into the interior locking tab.
    • When locked in place, the Hello from Seattle line will be parallel with the device's sides.
    Demander à FixBot
Congratulations on completing your repair!
Spencer Day
Membre depuis le 09/14/22
191 211 Réputation
1 204 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
122 membres
25 946 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 13
30 derniers jours : 37
Total : 481
