Introduction
Use this guide to replace the SSD in your Xiaomi Air 12.
Orient the computer so the Xiaomi logo is at the bottom of the device.
  • Orient the computer so the Xiaomi logo is at the bottom of the device.
Ajouter un commentaire
Insert the plastic opening tool underneath the top-middle rubber covering and lift upwards to reveal the hidden screw. Insert the plastic opening tool underneath the top-middle rubber covering and lift upwards to reveal the hidden screw. Insert the plastic opening tool underneath the top-middle rubber covering and lift upwards to reveal the hidden screw.
  • Insert the plastic opening tool underneath the top-middle rubber covering and lift upwards to reveal the hidden screw.
Remove the eight 3 mm screws using the Torx T5 driver by inserting the screwdriver into each screw and rotating counterclockwise. Remove the eight 3 mm screws using the Torx T5 driver by inserting the screwdriver into each screw and rotating counterclockwise.
  • Remove the eight 3 mm screws using the Torx T5 driver by inserting the screwdriver into each screw and rotating counterclockwise.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Insert the plastic opening tool into each side of the computer and push the tool downwards to pop open the back cover. You will hear popping noises as you remove the cover. You will hear popping noises as you remove the cover.
  • Insert the plastic opening tool into each side of the computer and push the tool downwards to pop open the back cover.
  • You will hear popping noises as you remove the cover.
Remove the back of the laptop by gently lifting the casing upwards. Remove the back of the laptop by gently lifting the casing upwards.
  • Remove the back of the laptop by gently lifting the casing upwards.
Detach the white and black speaker wires by pulling them from the small black tabs along the perimeter of the metal bracket. Detach the white and black speaker wires by pulling them from the small black tabs along the perimeter of the metal bracket.
  • Detach the white and black speaker wires by pulling them from the small black tabs along the perimeter of the metal bracket.
Remove the 1.5mm screw using the JIS #00 screwdriver. Remove the 1.5mm screw using the JIS #00 screwdriver.
  • Remove the 1.5mm screw using the JIS #00 screwdriver.
Lift the SSD up from the device and gently pull the SSD from the laptop. Lift the SSD up from the device and gently pull the SSD from the laptop.
  • Lift the SSD up from the device and gently pull the SSD from the laptop.
Hannah Kwan
Membre depuis le 18/04/2018
653 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team S18-G4, Livingston Spring 2018 Membre de l'équipe Cal Poly, Team S18-G4, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G4
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 46
Total : 109
