Aller au contenu principal
XtremeMac Luna Dock Circuit Board Replacement
Ce dont vous avez besoin
  1. XtremeMac Luna Dock Circuit Board Replacement, Bottom Panel: étape 1, image 1 de 3 XtremeMac Luna Dock Circuit Board Replacement, Bottom Panel: étape 1, image 2 de 3 XtremeMac Luna Dock Circuit Board Replacement, Bottom Panel: étape 1, image 3 de 3
    • Flip the device over so that the batteries are closest to you.
    • Remove the battery lid by pressing the battery cover's tab and pulling it away from the device.
    • Push the battery against the spring and lift it out of the casing.
    • Repeat with the other battery.
  2. XtremeMac Luna Dock Circuit Board Replacement: étape 2, image 1 de 1
    • Unscrew all eight 12mm Phillips head screws with a Philips #1 screwdriver.
    • The iFixit 26 bit screwdriver kit will not reach the screws. Make sure to use a screwdriver that is thin enough to not get stuck in the screw holes.
  3. XtremeMac Luna Dock Circuit Board Replacement: étape 3, image 1 de 2 XtremeMac Luna Dock Circuit Board Replacement: étape 3, image 2 de 2
    • Flip the Luna back over so that the buttons are facing upward and the LCD screen is facing you.
    • Gently tilt the lid back 45 degrees so that the inside is exposed.
    • Be mindful of the wires inside of the Luna. It is easy to break a connection if a wire gets caught.
  4. XtremeMac Luna Dock Circuit Board Replacement, Dock Circuit Board: étape 4, image 1 de 3 XtremeMac Luna Dock Circuit Board Replacement, Dock Circuit Board: étape 4, image 2 de 3 XtremeMac Luna Dock Circuit Board Replacement, Dock Circuit Board: étape 4, image 3 de 3
    • Unscrew the four black 7mm screws with the Phillips #1 screw driver that hold the middle circuit board to the top case.
Matt Ducasse
Membre depuis le 04/18/13
12 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 3-47, Amido Spring 2013 Membre de l'équipe Cal Poly, Team 3-47, Amido Spring 2013
CPSU-AMIDO-S13S3G47
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 465
