Introduction
Learn to remove and replace a speaker for your keyboard with this guide. The process is fairly simple and mostly requires the removal of screws.
Turn the keyboard over so that the keys are facing the ground.
  • Turn the keyboard over so that the keys are facing the ground.
Ajouter un commentaire
Pop the tabs on the battery casing and remove it from the back plate.
  • Pop the tabs on the battery casing and remove it from the back plate.
Locate the six batteries and remove them from the battery cavity.
  • Locate the six batteries and remove them from the battery cavity.
what type of batteries? and how much ?
thanks godbless
colladonelson - Réponse
Remove the six 10mm screws at the top of the backplate.
  • Remove the six 10mm screws at the top of the backplate.
Remove the seven 12mm screws in the middle of the back plate.
  • Remove the seven 12mm screws in the middle of the back plate.
Remove the eight 10mm screws from the side and the bottom of the back plate.
  • Remove the eight 10mm screws from the side and the bottom of the back plate.
As the face plate is no longer connected to the body of the keyboard, be careful to not drop the body when performing this step.
  • As the face plate is no longer connected to the body of the keyboard, be careful to not drop the body when performing this step.
  • Flip over the keyboard
Lifting from the front and the back of the face plate equally, pull the face plate up and then back, away from the keyboard. Be careful when removing the face plate. There are wires attached.
  • Lifting from the front and the back of the face plate equally, pull the face plate up and then back, away from the keyboard.
    • Be careful when removing the face plate. There are wires attached.
Locate the speaker and remove the four 10mm screws in the corners of the speaker.
  • Locate the speaker and remove the four 10mm screws in the corners of the speaker.
Unplug the speaker's black and red wires from the small circuit board.
  • Unplug the speaker's black and red wires from the small circuit board.
    • Do not be afraid to use a little force to get the plug out, but take care not to pull the wires from the plug.
Remove the translucent blue tape that holds the speaker wires to the keyboard.
  • Remove the translucent blue tape that holds the speaker wires to the keyboard.
Lonnie Bissmeyer
Membre depuis le 16/09/2012
288 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 2-62, Propen Fall 2012 Membre de l'équipe Cal Poly, Team 2-62, Propen Fall 2012
CPSU-PROPEN-F12S2G62
2 membres
6 tutoriels rédigés
I need to replace a speaker on a Yamaha YPG-625 88 note digital piano .....is this the same thing I should do like the piano you are showing on this web sight ? Also the big screen in the middle of the piano that says what tone you select and the drum patterns is sorta kinda going out ! could it be just getting dirty and need contact cleaning ? The place that sells these Yamaha pianos said they would have to send it away to have the repairs done and the cost would be OVER $500.00 ! Any help would be greatly helpful ! Mark Rockwell Galena , Il flyingfingersmark1@yahoo.com 815-777-4928
flyingfingersmark1 - Réponse
Voir les statistiques:
Dernières 24 heures : 5
7 derniers jours : 25
30 derniers jours : 83
Total : 4,473
