Introduction
Using the plastic opening tool and the Phillips #0 screw driver we will remove the camera sensor.
Remove the SD card and the Sim card from the device.
  • Remove the SD card and the Sim card from the device.
Ajouter un commentaire
Use an plastic opening tool or your hands to peel the back off the device. Use an plastic opening tool or your hands to peel the back off the device.
  • Use an plastic opening tool or your hands to peel the back off the device.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the three screws (1.6mm) that secure the top plastic motherboard cover using the Phillips #0 screwdriver head from the plastic tool kit.
  • Remove the three screws (1.6mm) that secure the top plastic motherboard cover using the Phillips #0 screwdriver head from the plastic tool kit.
  • One of our screws was missing but follow the locations on the picture.
Remove the top plastic motherboard cover using a plastic opening tool. Remove the top plastic motherboard cover using a plastic opening tool. Remove the top plastic motherboard cover using a plastic opening tool.
  • Remove the top plastic motherboard cover using a plastic opening tool.
Unclip the camera module cable from its port using the plastic opening tool. Unclip the camera module cable from its port using the plastic opening tool.
  • Unclip the camera module cable from its port using the plastic opening tool.
Remove camera module with fingers or anything you so please.
  • Remove camera module with fingers or anything you so please.
Michael Gonzalez
Membre depuis le 29/01/2018
445 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S5-G2, Passmore Spring 2018 Membre de l'équipe USF Tampa, Team S5-G2, Passmore Spring 2018
USFT-PASSMORE-S18S5G2
3 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 17
