Introduction
This guide will show you how to replace the battery on your ZTE ZMAX.
Insert a fine point tool into the hole on the top left side of the phone to remove the SIM and SD card trays. Pull out the trays.
  • Insert a fine point tool into the hole on the top left side of the phone to remove the SIM and SD card trays.
  • Pull out the trays.
Ajouter un commentaire
Insert a plastic opening tool into the groove between the phone’s back cover and casing. Move the plastic opening tool along the edges of the phone to unclip the two pieces.
  • Insert a plastic opening tool into the groove between the phone’s back cover and casing.
  • Move the plastic opening tool along the edges of the phone to unclip the two pieces.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the ten 1.2mm screws with a Phillips #000 screwdriver. Remove the ten 1.2mm screws with a Phillips #000 screwdriver. Remove the ten 1.2mm screws with a Phillips #000 screwdriver.
  • Remove the ten 1.2mm screws with a Phillips #000 screwdriver.
Remove the mid frame with the plastic opening tool. Remove the mid frame with the plastic opening tool.
  • Remove the mid frame with the plastic opening tool.
Disconnect the battery from the motherboard. Disconnect the battery from the motherboard.
  • Disconnect the battery from the motherboard.
Wedge a spudger underneath the battery and gently pry upwards to remove the battery. Once free from the glue, remove from device.
  • Wedge a spudger underneath the battery and gently pry upwards to remove the battery.
  • Once free from the glue, remove from device.
  • The glue holding down the battery is strong so work slow and cautiously to avoid starting a fire.
Burak Cengiz
Membre depuis le 15/02/2018
450 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S17-G3, Boczar Spring 2018 Membre de l'équipe USF Tampa, Team S17-G3, Boczar Spring 2018
USFT-BOCZAR-S18S17G3
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 14
30 derniers jours : 61
Total : 128
