Introduction
This guide will show you how to replace the front-facing camera of the phone. You will need a plastic opening tool, tweezers, and a #00 Phillips screwdriver to replace the camera.
Flip the phone over so that the back panel of the phone is facing up.
  • Flip the phone over so that the back panel of the phone is facing up.
  • Wedge the plastic opening tool between the black outer panel and the silver side panel.
  • Push down on the plastic opening tool to separate the back panel from the rest of the phone.
  • Continue to do this around all sides of the phone until the back panel has popped all the way off.
  • Removing the back panel may make loud popping noises which is normal.
Ajouter un commentaire
Using your fingers, slide the SIM card all the way out of the phone.
  • Using your fingers, slide the SIM card all the way out of the phone.
Remove the yellow Kapton tape by using the tweezers to peel it up and away from the device. Remove the yellow Kapton tape by using the tweezers to peel it up and away from the device.
  • Remove the yellow Kapton tape by using the tweezers to peel it up and away from the device.
Using the Phillips #00 screwdriver, remove the two 3.0 mm screws located near the top of the phone, next to the rear camera.
  • Using the Phillips #00 screwdriver, remove the two 3.0 mm screws located near the top of the phone, next to the rear camera.
Idées cadeaux pour la Fête des Pères
Mettons nos papas à l’honneur ainsi que nos mentors qui nous ont appris à réparer.
Honorons ceux qui nous ont enseigné à réparer.
Remove the  fingerprint sensor flex cable, using the plastic opening tool to lift it out.
  • Remove the fingerprint sensor flex cable, using the plastic opening tool to lift it out.
Using the tweezers, peel back the yellow Kapton tape located on the right side of the phone. Using the tweezers, peel back the yellow Kapton tape located on the right side of the phone.
  • Using the tweezers, peel back the yellow Kapton tape located on the right side of the phone.
Using the Phillips #00 screwdriver, remove the 15,  3.0 mm rear panel screws located around the perimeter of the phone.
  • Using the Phillips #00 screwdriver, remove the 15, 3.0 mm rear panel screws located around the perimeter of the phone.
Flip the phone over so that the screen is facing up.
  • Flip the phone over so that the screen is facing up.
  • Wedge the plastic opening tool between the screen and the rear panel.
  • Push up on the opening tool to separate the panel from the phone.
  • Continue to do this around the entire phone until the rear panel is no longer connected to the device.
  • The rear case and screen are fastened tightly to each other. It might help to use the picks as wedges to keep the case and screen separated as you run the opening tool along the edges.
Wedge the plastic opening tool under the front-facing camera. It's located on the top, right side of the motherboard.
  • Wedge the plastic opening tool under the front-facing camera. It's located on the top, right side of the motherboard.
  • Push down on the plastic opening tool to make the camera pop out of the device.
Use your fingers to pull the camera all the way out of the phone.
  • Use your fingers to pull the camera all the way out of the phone.
Nicholas Leacox
Membre depuis le 18/04/2018
787 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team S17-G3, Livingston Spring 2018 Membre de l'équipe Cal Poly, Team S17-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G3
4 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 46
