Introduction
When your memory card is full, you can follow these steps to install another microSD card in your iON.
Peel the rubber cover for the memory card and USB port away from the goggles. Be careful not to completely remove the cover!
  • Peel the rubber cover for the memory card and USB port away from the goggles.
  • Be careful not to completely remove the cover!
Ajouter un commentaire
Push the memory card in until you hear it click. Pull your finger away.
  • Push the memory card in until you hear it click.
  • Pull your finger away.
  • If you pull your finger away too quickly, the card can completely pop out of the slot and could get lost!
  • The memory card will pop out about half way out of its slot.
Pull the memory card straight out of its slot. Pull the memory card straight out of its slot.
  • Pull the memory card straight out of its slot.
Eric Flores
Membre depuis le 31/07/2012
126 Réputation
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,166
