Danger
Potentiellement dangereux
Risque de blessure si cette procédure n'est pas suivie correctement. Faites preuve de prudence et suivez tous les avertissements.
Danger
Introduction
This guide shows how to disassemble and replace the battery within the device.
Power off the device and keep it unplugged. Open the case using a plastic opening tool around the edges. Slightly pull the cover.
  • Power off the device and keep it unplugged.
  • Open the case using a plastic opening tool around the edges. Slightly pull the cover.
  • Do not completely remove back casing because there is a speaker attached to the back.
Ajouter un commentaire
Cut the power cables connecting between the screen and the motherboard. There should be a red and black cable each. Try to cut in the center of the two wires to solder after you replace it. Try to separate the wires away from the other wires on the motherboard. This way you will not cut any additional wiring.
  • Cut the power cables connecting between the screen and the motherboard. There should be a red and black cable each. Try to cut in the center of the two wires to solder after you replace it.
  • Try to separate the wires away from the other wires on the motherboard. This way you will not cut any additional wiring.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Peel off the battery from the metal casing for the LED screen. The battery will be held down with an adhesive, and it will not take much pressure to be released. There will be additional wiring hooked up to the motherboard. Make sure not to tangle up or damage any wiring close by.
  • Peel off the battery from the metal casing for the LED screen. The battery will be held down with an adhesive, and it will not take much pressure to be released.
  • There will be additional wiring hooked up to the motherboard. Make sure not to tangle up or damage any wiring close by.
  • Do not place much pressure onto the LED screen while peeling off the battery.
After creating space to work, warm up a soldering iron.
  • After creating space to work, warm up a soldering iron.
  • Apply heat onto the solder over the corresponding cut wire to the new battery wire.
  • Once the solder melts and forms a bridge between the two wires, try to turn on the device then check for power.
  • Comment souder et dessouder des connexions
  • Keep the soldering iron away from the battery, motherboard, and any other wires. Do not let children around the soldering station.
To reassemble your device, follow the initial instructions in reverse order.
Jacob
Membre depuis le 26/03/2018
121 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S2-G1, Harley Spring 2018 Membre de l'équipe IUPUI, Team S2-G1, Harley Spring 2018
IUPUI-HARLEY-S18S2G1
3 membres
2 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 83
