Aller au contenu principal
Zoomer Meowzies Battery Replacement
Ce dont vous avez besoin
  1. Zoomer Meowzies Battery Replacement, Battery: étape 1, image 1 de 2 Zoomer Meowzies Battery Replacement, Battery: étape 1, image 2 de 2
    • Turn the Zoomer Meowzies over so it is on its back and its stomach is facing up.
    • Using the Phillips #1 screwdriver, loosen the screw holding the battery compartment closed.
    • This screw has a collar that will prevent it from being completely removed and therefore cannot be measured or replaced.
  2. Zoomer Meowzies Battery Replacement: étape 2, image 1 de 2 Zoomer Meowzies Battery Replacement: étape 2, image 2 de 2
    • Lift the compartment cover from the body. Due to the ribbon on the cover, the batteries should pop out as you remove the cover.
    • Replace with new batteries using the diagrams located within the compartment as a guide for correct battery orientation.
    • When replacing the batteries, weave the ribbon under each battery for easy removal later.
Mitchell Gentry
Membre depuis le 02/14/18
675 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S6-G2, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S6-G2, Eyestone Spring 2018
USFT-EYESTONE-S18S6G2
3 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 11
Total : 851
