Aller au contenu principal
Zune Flash 2nd Generation Center Frame Replacement
Ce dont vous avez besoin
  1. Zune Flash 2nd Generation Center Frame Replacement, Back Cover: étape 1, image 1 de 2 Zune Flash 2nd Generation Center Frame Replacement, Back Cover: étape 1, image 2 de 2
    • Prior to disassembly, verify the hold switch is engaged to ensure the device will not turn on during the procedure.
    • If the device turns on while it is being disassembled it could cause irreversible damage to the device.
    • PICS MAKE NO SENSE.
  2. Zune Flash 2nd Generation Center Frame Replacement: étape 2, image 1 de 2 Zune Flash 2nd Generation Center Frame Replacement: étape 2, image 2 de 2
    • Remove the top metal clip by inserting a Zune opening tool in between the faceplate and back cover and pulling gently back as shown in the images.
    • You should hear a 'click' as the clip detaches from the device.
  3. Zune Flash 2nd Generation Center Frame Replacement: étape 3, image 1 de 1
    • Remove the two screws shown using a Y00 Tri-Wing screwdriver.
  4. Zune Flash 2nd Generation Center Frame Replacement: étape 4, image 1 de 3 Zune Flash 2nd Generation Center Frame Replacement: étape 4, image 2 de 3 Zune Flash 2nd Generation Center Frame Replacement: étape 4, image 3 de 3
    • Insert the Zune opening tool between the faceplate and the back cover, starting from the top and slowly work your way around the device.
  5. Zune Flash 2nd Generation Center Frame Replacement: étape 5, image 1 de 3 Zune Flash 2nd Generation Center Frame Replacement: étape 5, image 2 de 3 Zune Flash 2nd Generation Center Frame Replacement: étape 5, image 3 de 3
    • Work your way around the Zune until the back cover comes free. Remove the back plate and set it aside.
  6. Zune Flash 2nd Generation Center Frame Replacement, Face Plate: étape 6, image 1 de 2 Zune Flash 2nd Generation Center Frame Replacement, Face Plate: étape 6, image 2 de 2
    • Remove the three screws (5.5mm by 3mm) from the backside of the Zune using a Y00 Tri-Wing screwdriver.
    • Be sure to put this set of screws aside since they are a different size than any other screws in the device.
  7. Zune Flash 2nd Generation Center Frame Replacement: étape 7, image 1 de 2 Zune Flash 2nd Generation Center Frame Replacement: étape 7, image 2 de 2
    • Use your finger or a Zune opening tool to pry back the two clear flaps.
    • Next lift the communications board that was being held down by the clear flaps.
    • Be careful not to accidentally detach the slim ribbon that connects between the communications board and the device.
  8. Zune Flash 2nd Generation Center Frame Replacement: étape 8, image 1 de 3 Zune Flash 2nd Generation Center Frame Replacement: étape 8, image 2 de 3 Zune Flash 2nd Generation Center Frame Replacement: étape 8, image 3 de 3
    • Disconnect the ribbon with the plastic opening tool by flipping up the black plastic flap where the ribbon connects to the memory board.
    • Carefully pull the ribbon out of the memory board, ensuring that the black plastic flap is up before removal to avoid the ripping the ribbon.
  9. Zune Flash 2nd Generation Center Frame Replacement: étape 9, image 1 de 3 Zune Flash 2nd Generation Center Frame Replacement: étape 9, image 2 de 3 Zune Flash 2nd Generation Center Frame Replacement: étape 9, image 3 de 3
    • Remove the battery by prying the battery off from the bottom with a Zune opening tool.
    • There is an adhesive between the battery and the device, therefore use a metal spudger to finish detaching the battery.
    • Be sure not to puncture the battery in any way when using the metal spudger.
  10. Zune Flash 2nd Generation Center Frame Replacement: étape 10, image 1 de 2 Zune Flash 2nd Generation Center Frame Replacement: étape 10, image 2 de 2
    • Remove the single screw under the battery using a small Tri-Wing screwdriver.
  11. Zune Flash 2nd Generation Center Frame Replacement: étape 11, image 1 de 1
    • Disconnect the faceplate from the device by depressing the two tabs located near the middle of each of the sides using a metal spudger.
    • This will disconnect the last circuit board in the device from the center frame.
  12. Zune Flash 2nd Generation Center Frame Replacement: étape 12, image 1 de 3 Zune Flash 2nd Generation Center Frame Replacement: étape 12, image 2 de 3 Zune Flash 2nd Generation Center Frame Replacement: étape 12, image 3 de 3
    • Remove the faceplate by using a metal spudger to separate it from the remaining components.
  13. Zune Flash 2nd Generation Center Frame Replacement, LCD Display: étape 13, image 1 de 1
    • Release the LCD connector ribbon by flipping up the black switch. This will disconnect the LCD from the device.
    • At this point the LCD screen should be easily separable from the device.
  14. Zune Flash 2nd Generation Center Frame Replacement: étape 14, image 1 de 3 Zune Flash 2nd Generation Center Frame Replacement: étape 14, image 2 de 3 Zune Flash 2nd Generation Center Frame Replacement: étape 14, image 3 de 3
    • The LCD ribbon is adhered to the memory board with a strip of glue.
    • It's safest to flip the display over before removing the ribbon, as shown in the first image.
    • To avoid damage, remove the LCD by pulling slowly and carefully on the ribbon, directly away from the memory board.
  15. Zune Flash 2nd Generation Center Frame Replacement, Center Frame: étape 15, image 1 de 3 Zune Flash 2nd Generation Center Frame Replacement, Center Frame: étape 15, image 2 de 3 Zune Flash 2nd Generation Center Frame Replacement, Center Frame: étape 15, image 3 de 3
    • Pry up the memory board from center piece with a Zune opening tool and gently pull it off.
killdashnine
Membre depuis le 10/19/09
100 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 9-20, Regan Fall 2009 Membre de l'équipe Cal Poly, Team 9-20, Regan Fall 2009
CPSU-REGAN-F09S9G20
5 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 2,867
