Introduction
This guide shows you how to replace the Zune Flash 2nd Generation face plate.
Ce dont vous avez besoin
Prior to disassembly, verify the hold switch is engaged to ensure the device will not turn on during the procedure.
If the device turns on while it is being disassembled it could cause irreversible damage to the device.
Remove the three screws (5.5mm by 3mm) from the backside of the Zune using a Y00 Tri-Wing screwdriver.
Be sure to put this set of screws aside since they are a different size than any other screws in the device.
2 autres ont terminé cette réparation.
